I don't know if it will help you, but some time ago I wrote a little routine for an 18F8722 running at either 20 or 40Mhz that lets you enter the PWM frequency and then increment and decrement the duty cycle with the UP and DOWN arrow keys on a keyboard.
It doensn't allow for infinite frequencies, but is a good test tool.
<CODE>
HSEROUT [13,10,10,"1. Test PWM ",13,10]
HSEROUT [13,REP 10\4]
HSEROUT ["Pick PWM Frequency 1 = 312Khz,2 = 156Khz, 3 = 78Khz, 4 = 39Khz "]
HSERin [Char]
IF Char < "1" or Char > "4" THEN
HSEROUT [13,10,10]
GOTO SpecialUse
IF Mhz40 = 1 THEN
Select CASE Char
CASE "1"
PWMFREQ = $1F
NumBits = 7
MaxPWM = 127
CASE "2"
PWMFREQ = $3F
NumBits = 8
MaxPWM = 255
CASE "3"
PWMFREQ = $7F
NumBits = 9
MaxPWM = 511
CASE "4"
PWMFREQ = $FF
NumBits = 10
MaxPWM = 1023
END SELECT
Select CASE Char
CASE "1"
PWMFREQ = $F
NumBits = 6
MaxPWM = 63
CASE "2"
PWMFREQ = $1F
NumBits = 7
MaxPWM = 127
CASE "3"
PWMFREQ = $3F
NumBits = 8
MaxPWM = 255
CASE "4"
PWMFREQ = $7F
NumBits = 9
maxPWM = 511
END SELECT
CCP1CON = %00001100
CCPR1L = %00010000
CCPR1H = %00000000 ' Initialize to 0, PWM register
PR2 = PWMFREQ
T2CON = %00000100 ' Prescale 1, Timer2 ON - Needed for PWM
PORTC.2 = 0
TRISC.2 = 0
PWMVal = 0
Gosub WritePWMreg
HSEROUT [13,10,10]
HSEROUT ["PWM Value (",#MaxPWM," Max)",13,10]
HSEROUT ["0",8]
NewChar:
HSERIN [Char]
If Char = 27 THEN
HSERIN 50,NoArrow,[Char2,Char3]
IF Char3 = 65 AND PWMVal < MaxPWM tHEN
PwmVal = PWMVal + 1
IF Char3 = 66 AND PWMVal > 0 tHEN
PwmVal = PWMVal - 1
HSEROUT [#PWMVal," ",REP 8\7]
GOSUB WritePWMReg
goto NewChar
NoArrow:
Break = 1
PWMVal = 0
Gosub WritePWMReg
CCP1CON = 0 ; Shut off the PWM controller
GOTO Begin
WritePWMReg:
CCPR1L = PWMVal >> 2
CCP1CON.5=PWMVal.1
CCP1CON.4=PWMVal.0
</CODE>
