connect microphone to pic?
Results 1 to 5 of 5
    Perth, Australia
    Default connect microphone to pic?
    I want to make a sound sensitive switch with a PIC. It needs to have variable sensitivity.
    What i'm thinking is, use a PIC with a AD converter, and compare the AD reading against the currently set sensitivity variable.
    What i'm not sure about is how to connect the microphone. Connecting the mic directly to an I/O pin surely wont work. I'm assuming i'd need some kind of amplification, but I have no idea where to start.
    Does any1 have any ideas?
    This looks like it might work.
    If you're using an electret microphone.
    http://www.alanmacek.com/usb/
    Look at the schematic near the bottom.
    Mentor, Ohio
    Smile
    Hi Kamikaze,
    If you want to consider another circuit, goto www.aaroncake.net/circuits and search for SOUND LEVEL METER. Where the input to the bar graph is you could feed that into a PIC analog pin and go from there.
    There are many published articles for what you want to do but I think after looking at Darrel's and mine you should be able to accomplish what you are looking to do.
    Did you get your other LCD project going? I was referring to using a serial LCD. Sparkfun has one very reasonably priced and very easy to work with.
    HTH,
    BobK
    Perth, Australia
    Thanks Darrel and BobK. I'll have a look at both of those now, and i'm sure i'll work it out.
    I got the LCD going. In the end i opted the easy way out and went with an 18-pin PIC instead of the 8-pin i wanted to use - Mainly to minimize the physical size of the circuit.
    Italy
    See page 7 of this application note.
    AVR335: Digital Sound Recorder with AVR® and DataFlash®
    http://www.atmel.com/dyn/resources/p...ts/doc1456.pdf
    Best regards,
    Luciano
  1. How to connect Buzzer to PIC?
    By koossa in forum Schematics
    Last Post: - 21st April 2010, 05:17
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. how to connect ac sensor to PIC ?
    By iugmoh in forum Schematics
    Last Post: - 1st June 2008, 19:35
  4. Microphone to PIC
    By scaenix in forum mel PIC BASIC Pro
    Last Post: - 10th March 2007, 21:13
