Questions about PIC16F677
Results 1 to 4 of 4
    Mar 2006
    Default Questions about PIC16F677
    I begin a project with PIC16F677 and I should like to ask the experts of
    this forum some questions.Here are some details of my application:
    1-Pins RA0, RA1 and RA3 are free. If I use internal pull up resistor for
    RA3/MCLR can I let this pin floating and save diode protection during programming?
    2- Pic will be feed through a batery and should be sleeping as much time
    as possible. I will use RA2 as an analog input and I pretend to use IOC
    for waking up the system when input RA2 changes but
    Which is the minimum input volt change for starting an IOC action?
    Is it a risky situation to use IOC for reliable operation of the system considering input signal RA3 is generated by an op-amp with high gain?
    3- For generating previous description I imagine I have to setup these registers:
    TRISA, ANSEL, IOCA, INTCON,ADCON0, ADCON1 and for disable comparators
    CM1CON0 and CM1CON1=0 but Do I forget anything else?
    Thank you in advanced for any help
    -Francesc
    Quote Originally Posted by fnovau View Post
    When the PIN is in Analog mode, a digital "Read" always returns 0.
    Therefore, an IOC will never happen.
    Mar 2006
    [QUOTE=fnovau;48669]I begin a project with PIC16F677 and I should like to ask the experts of
    Does anybody can answer or give me any hint about question 1?
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Yes - if you are using RA3 as MCLR (MCLRE = 1), the internal pull-up will keep it high so you do not need to tie this pin to anything, which saves the diode between the pin and the VDD rail. However, if you are in a noisy environment, you might want to consider using the internal MCLR pull-up (MCLRE = 0) or add the diode and a 1.0K resistor in line to the rail.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. Two quick (and elementary) questions.
    By scorpion990 in forum mel PIC BASIC Pro
    Last Post: - 27th June 2008, 00:03
  2. A few 12F683 questions
    By dhouston in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 04:54
  3. Usart Questions
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 8th March 2008, 02:17
  4. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 19:27
  5. Hi Everyone! Some newbie questions :-)
    By guest_05 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2006, 23:24
