I/O dilemma
Results 1 to 4 of 4
Thread: I/O dilemma
    Perth, Australia
    Default I/O dilemma
    I'm working on a project where I would like to hook up 1 LCD and 1 button to an 8-pin 12F683 which only has 6 I/O pins. However, the LCD requires 6 and the button requires 1.
    Can anybody think of a solution that would not require any additional components?
    Is it possible to use the LCD with only 5 I/O pins perhaps?
    Oct 2003
    holland
    You can sent data to the display with 6 output lines.
    Then after sending you make one output pin an input.
    look if the input is changing and react on that.
    Then if you want to sent som new data to the display make that pin an output again and sent the data to the display.
    Edit:
    Sorry I saw in the datasheet that this part has only 5 outputs and 1 input what cannot set to an output.
    You can take a shiftregister where you sent via the shiftout instruction the 6 lines data to the display. It costs you now only 2 or 3 output lines. How you can do this is already done here in this forum.
    Via search you can find it.
    Perth, Australia
    I assume the shift register idea would require additional hardware? This is something I was trying to avoid.
    I didn't notice that one of my i/o pins was input only. This means that I have no chance hooking up the LCD unless it can be done with only 5 outputs.
    Mentor, Ohio
    Smile
    Hi Kamikaze,
    Have you given any thought to a serial LCD display? Only needs 1 pin from the micro.
    HTH,
    BobK
  1. PORTA Logic - Be the processor
    By Darrel Taylor in forum FAQ - Frequently Asked Questions
    Last Post: - 9th March 2009, 19:18
  2. I/O extender
    By mychangl in forum mel PIC BASIC Pro
    Last Post: - 20th November 2008, 15:56
  3. MCP23016 I2C serial I/O expander chip
    By GeoJoe in forum Serial
    Last Post: - 31st October 2007, 16:39
  4. 16F877 universal PCB with I/O module
    By cupajoe in forum Schematics
    Last Post: - 3rd September 2005, 14:39
  5. managing the I/O ports of the 16F84A
    By skyler_91600 in forum mel PIC BASIC
    Last Post: - 28th April 2005, 04:52
