Help with LCD commands with button I/P
Results 1 to 23 of 23
    Yes i know... look how your program flow...
    it goes to Disp1 or Disp2.. then it return to Loop... knowing that SW1 can't something else than 0 or 1.. it will never execute the IF SW4 = lines.
    I would suggest to use GOSUB and RETURN for a quick fix.. and be careful with LCDOUT $FE,1 line in DISP3 & DISP4 routines...
    Still possible to use another method...
    Oct 2007
    Thanks I will give it a try,
    you could still use something like..
    Loop:
            IF SW0=0 THEN
                    '  Paste your Disp1 stuff here
                                    ' paste your Disp2 Stuff here
            IF SW4 = 0 then
                    ' Pate your DISP3 stuff here
                                    ' paste your DISP4 stuff here
            GOTO Loop
    Oct 2007
    Sorted.
    I just inserted a cupple of goto's and returns and It works fine on both lines now,
    Many thanks for you and all for your help and advice,
    Just one last thing, do you know of where I can get a list of lcdout $ commands as I would like to insert extra info togged by unused i/p's
    Dave...
    The PBP manual has some. What are you looking for exactly?
    Oct 2007
    Default lcd commands wanted
    I am looking for the lcdout commands, so I am able to send text to any position on a two line display,
    Say, 1 command at the beginning of line 1 and another at the end of line 1
    cheers
    Dave..
    Thats easy. Look in the manual for full explanation.
    LCDOUT $FE, 80 ' First position of line one
    LCDOUT $FE, 80 + 4 ' Move over 4 places to the right
    Same works for the second line where $C0 is the first position.
    Oct 2007
    Just what I was looking for,
    I can't find my manual so it was just as easy to ask.
    Cheers
    Dave..
  1. 16f688 LCD what have I done wrong
  2. LCD will not start
  3. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
  4. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
