Help with LCD commands with button I/P
Results 1 to 23 of 23
    Oct 2007
    Default Help with LCD commands with button I/P
    Hi all,
    I am a newbie and I am looking for any pointers on a little problem i have.
    I am trying to get a 2 line LCD display to change its display when it recieves a logic input.
    (I am using a 2 line display and a 16F627)
    I can get it to display anything I want with the LCDOUT command,
    My problem starts when I try to change the displayed words when I recieve an input,
    For test purposes I attached a button to the input,
    The best I could get was the display to flash both commands when the button was pressed.
    Any ideas ?
    Cheers
    Dave...
    Why not just use and if...then statement and use the button to input to toggle between the two display outputs.
    Oct 2007
    Default Still having problems....
    Thanks for your reply,
    The program I am trying to get going is to get an lcd display to display the status of a low power ham radio repeater,
    The pic's i/p lines will be connected to the control lines of the radio control circuit.
    I have re-writen the program using the IF, THEN commands and all I get is the setup message and lcd back light,
    The display remains blank no matter what the i/p lines are doing.
    (I/P pins are 10k to Gnd.)
    The program I am trying to get working follows:-
    (please feel free to rip it apart and advise me where I am going wrong)
    Cheers
    Dave...
    TRISA=%00000000 'Set port A as output
    TRISB=%01110111 'Set port B as input except B7 for backlight and B3 for lcd
    Backlight VAR PortB.7 'Set var as port B7
    SW1 VAR PORTB.0
    SW2 VAR PORTB.1
    SW3 VAR PORTB.2
    SW4 VAR PORTB.4
    SW5 VAR PORTB.5
    SW6 VAR PORTB.6
    Pause 500 'stand by for lcd
    lcd_light: 'light up lcd backlight
    low Backlight
    gosub setup
    goto loop
    setup:
    LCDOUT $FE,1 'clear lcd
    lcdout " G7JIQ Micro" 'Display on line 1
    lcdout $FE, $C0 'Display on line 2
    Lcdout " Link Repeater"
    pause 2000
    LCDOUT $FE, $0C 'turn off cursor
    lcdout $FE,1 'clear display
    lcdout $FE,2
    loop:
    if SW1 = 0 then Disp1
    if SW1 = 1 then Disp2
    IF SW4 = 0 THEN Disp3
    if SW4 = 1 THEN Disp4
    goto loop
    Disp1
    lcdout "Standby"
    Disp2
    lcdout "Main"
    Disp3
    lcdout $FE,$C0,"Local off " 'display on line 2
    lcdout $FE,1
    Disp4
    LCDOUT $FE,$C0,"local on"
    lcdout $FE,1
    Hi g7jiq,
    looks simple enough, without my trying your code. You want Disp1, disp2, to run only when sent there,
    your code
    Disp1
    lcdout "Standby"
    Disp2
    lcdout "Main"
    Disp3
    lcdout $FE,1
    Disp4
    lcdout $FE,1
    try:
    Disp1:
    lcdout "Standby"
    Disp2:
    lcdout "Main"
    Disp3:
    lcdout $FE,1
    Disp4:
    lcdout $FE,1
    without the colons the program sees your subdirectories as just the next line of code, the returns send it back to the line after the one which calls it.
    JS
    I may be wrong but would you not require a gosub in order to use a return? I believe a simple goto would me more appropriate in this case.
    and there's another danger... DISP3, DISP4,, the second LCD will clear the whole LCd display.
    Quote Originally Posted by CocaColaKid View Post
    YEP!
    Shows how close I looked at the code after seeing what I did see! Must have gotten excited.
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. LCD will not start
  3. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  4. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
