16F877 upgrade to 18F4620
Results 1 to 8 of 8
    Mar 2006
    China
    Default Are we reading the same datasheet?
    I downloaded the pdf file from microchip's webpage and read it.
    It said:
    Two External Clock modes, up to 40 MHz
    These 2 modes are:
    9. EC External Clock with FOSC/4 Output
    10. ECIO External Clock with I/O on RA6
    So it is not possible to use the PLL in these modes but the PIC will run at 40 Mhz if it has a 40 Mhz oscillator connected. I run several 4620 on 40 Mhz, both as 10 Mhz +4*PLL and as pure 40 Mhz circuits.
    Also can this be found under absolute maximium ratings:
    All devices 15 35 mA -40°C
    VDD = 4.2V
    FOSC = 40 MHZ
    (PRI_RUN,
    EC oscillator) <--------- look here!!!
    16 35 mA +25°C
    16 35 mA +85°C
    All devices 21 40 mA -40°C
    21 40 mA +25°C VDD = 5.0V
    21 40 mA +85°C
    So there should be no problem at att to run a 18F4620 with EC or ECIO configuration bits from an external 40 MHz oscillator if Vdd > 4.2V and if it is an industrial rated PIC (figure 26-1) the LF and extended rated PIC has a different behaviour.
    /me
    Quote Originally Posted by Jumper View Post
    These 2 modes are:
    /me
    I'll be.... guess I should have read further into it.
    Oh well. Run 10Mhz external gives the option of a sort of clock throttling anyways, switching between the various oscillators, both internal and external. I use it a lot to save battery juice.
  1. 16f877 to 18f4620 need help
    By vicce67 in forum mel PIC BASIC Pro
    Last Post: - 4th January 2010, 09:20
  2. 16f877 and ps/2 keyboard error???
    By boraciner in forum mel PIC BASIC Pro
    Last Post: - 5th July 2009, 09:14
  3. 18F4620 and SHT11 problems
    By wjsmarine in forum mel PIC BASIC Pro
    Last Post: - 27th June 2009, 11:26
  4. serial communication between CMUcam and PIC 16F877
    By gengkeys in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 07:43
  5. 4 Quadrant dc drive with 16F877
    By mns45 in forum mel PIC BASIC
    Last Post: - 23rd February 2006, 14:05
