log10 function
Results 1 to 8 of 8
Thread: log10 function
    dampf's Avatar
    dampf Guest
    Default log10 function
    I have just started writing code in meLabs PicBasic Pro compiler and have so far had great success.
    I now need to write a program using 32 bit floating point numbers and a log10 function. I have the floating point part of it working flawlessly. But I have no idea what to do about log10. I downloaded code from Microchip (App Note 660) but I have no idea how to integrate this into my project.
    If anyone has done this before, or if they know of another way of doing log10 I would appreciate any help you could give.
    If you need any more information please ask me.
    Thanks in advance.
    in which formula will you use LOG10 ???
    sometime you can refer to simples SCHAUM math series.
    let me know
    dampf's Avatar
    dampf Guest
    I am not sure I understand your question. This is how I intend on using log10:
    result = log10(1/x) - log10(1/y)
    x and y are both average values obtained from an analog to digital converter. They are btoh 16 bit integers which I have converted to floating point for this function.
    Dec 2003
    Wichita KS
    Hello Dampf,
    D>>If anyone has done this before, or if they know of another way of doing log10 I would appreciate any help you could give.<<
    There is a Taylor Series that calculates this. Search in the forum for Tayolr Series, and you should come up with a thread that has calculating Sin via Taylor series.
    I will look up the Series for Log base 10... My calculus is a little rusty in remembering these things.
    Dwayne
    Ability to Fly:
    Hurling yourself towards the ground, and missing.
    Engineers that Contribute to flying:
    Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute
    Pilots that are Flying:
    Those who know their limitations, and respect the green side of the grass...
    anj's Avatar
    anj Guest
    Gday Dampf
    For logarithms
    log(1/n) = - log(n)
    log(x/y) = log(x)-log(y)
    therefore ( assuming x and y stay integers ) you can rewrite
    result = log10(1/x) - log10(1/y) to use integers only
    using above relationships you get the following
    result = log10(y/x)
    and hence
    result = log10(y) - log10(x) <-use this instead as easier to calc
    I found a nice way to calc logs in base2 which you then convert to baseE / base10 etc as you choose by using a std conversion factor. If you read the "logarithm by calculation" section from
    http://www.emesys.com/BS2math3.htm it explains it very well and gives a BS2 code example that you can modify to suit PBP fairly easily.
    It has a small footprint and appears to work quite well.
    May help you out
    Andrew
    dampf's Avatar
    dampf Guest
    Hello Anj, and thank you.
    I inserted (after slight modification) that routine into my program and it worked great. My only problem is that it only carries it out to 4 places after the decimal point (4.0796 for example). For my application I need a bit more accuracy .. at least a couple more places to the right of the point.
    anj's Avatar
    anj Guest
    Gday Dampf
    If that method isnt accurate enough for you, and you have floating point routines, you may want to look at
    http://www.dattalo.com/technical/theory/logs.html
    Section 5 gives the taylor series method of calculating ln(x), and you can expand this as far as reqd to get the accuracy you require. Not sure if the pic will handle the calcs though )
    If it can, then you just use the same method as before to reduce back to log10.
    I havent used this method with a PIC, but it may help with what you are trying to do.
    Andrew
    dampf's Avatar
    dampf Guest
    Thanks everyone for all of your help.
    Using the integer LOG10 program from http://www.emesys.com/BS2math3.htm, The ln(x) series from http://www.dattalo.com/technical/theory/logs.html and a bunch of log10/ln/log2 relationships I came up with something that I am happy with.
    If anyone wants to use this, feel free. And I am sure some of you smarter folks out there will be able to simplify this greatly. This was fast, dirty, commented poorly, but very rewarding haha.
    To use this you must have the floating point routines installed.
    y = 16bit integer (I left y=12013 in this program for testing purposes)
    there is a loop that goes from 2 to 10. The more times through the loop, the more accurate you get.
    Any questions, feel free to ask.
    Thanks again for all of your help!!
    ' LOG10 using LOG2 and LN
    y var word ' to hold an input number from 1 to 65535
    x var word ' for processing the number
    log var word ' to hold the log base 10
    j var byte ' loop variable
    k var byte ' loop variable
    cc var byte ' characteristic
    z1 var byte[4] ' to store results
    z2 var byte[4] ' to store results
    LOG10:
    ' lg(y) = lg(y/2^cc * (y/(y/2^cc))) = lg(y/2^cc) + lg(y/(y/2^cc))
    ' = cc + ln(y/2^cc) / ln(2) = cc + ln(y/2^cc) * 1.442695
    ' starting value y, will be sum from a to d converter
    y = 12013 ' log10(y) = 4.07965
    cc = ncd y - 1 ' find the characteristic
    aint = 1 ' now find 2^cc
    Gosub itofa ' a holds the results
    bint = 2
    Gosub itofb
    for i = 1 to cc ' multiply by 2 cc times
    gosub fpmul
    next i
    bint = y
    gosub itofb
    ' now barg equals y
    ' swap a and b
    swap AEXP, BEXP
    Swap AARGB0, BARGB0
    Swap AARGB1, BARGB1
    Swap AARGB2, BARGB2
    gosub fpdiv ' a = a/b = y / 2^cc
    ' now for the fun stuff. We know y / 2^cc < 2 and > 0, so
    ' calculate ln(a) where -1 < x < 1 using
    ' ln(1+a) = a - a^2/2 + a^3/3 - a^4/4 + ... - (-a)^n/n
    ' or ln(a) = (a-1) - (a-1)^2/2 + (a-1)^3/3 - (a-1)^4/4 + ... - (-(a-1))^n/n
    bint = 1
    gosub itofb
    gosub fpsub ' a = a - 1
    z2[0] = AEXP
    z2[1] = AARGB0
    z2[2] = AARGB1
    z2[3] = AARGB2
    ' z2 will hold the results
    BEXP = AEXP
    BARGB0 = AARGB0
    BARGB1 = AARGB1
    BARGB2 = AARGB2
    aint = 0
    gosub itofa
    gosub fpsub ' a = - a
    z1[0] = AEXP
    z1[1] = AARGB0
    z1[2] = AARGB1
    z1[3] = AARGB2
    ' z1 = -a
    for j = 2 to 10 ' 10 times is accurate enough for us
    aint = 1
    gosub itofa
    BEXP = z1[0]
    BARGB0 = z1[1]
    BARGB1 = z1[2]
    BARGB2 = z1[3]
    for k = 1 to j
    gosub fpmul ' a = a * b .. a starts as a .. b starts as a
    next k
    bint = j
    gosub itofb
    gosub fpdiv ' a should now = (-(a-1))^n/n
    BEXP = AEXP
    BARGB0 = AARGB0
    BARGB1 = AARGB1
    BARGB2 = AARGB2 ' now b = a
    AEXP = z2[0]
    AARGB0 = z2[1]
    AARGB1 = z2[2]
    AARGB2 = z2[3]
    gosub fpsub ' a = results - b
    z2[0] = AEXP
    z2[1] = AARGB0
    z2[2] = AARGB1
    z2[3] = AARGB2
    next j
    ' now multiply by 1.442695
    AEXP = z2[0]
    AARGB0 = z2[1]
    AARGB1 = z2[2]
    AARGB2 = z2[3]
    BEXP = $7F
    BARGB0 = $38
    BARGB1 = $AA
    BARGB2 = $3B
    gosub fpmul
    bint = cc
    gosub itofb
    gosub fpadd ' a = a + cc = lg(y)
    'log(y) = lg(y) / lg(10) = lg(y) * 0.301029996
    BEXP = $7D
    BARGB0 = $1A
    BARGB1 = $20
    BARGB2 = $9B
    gosub fpmul
    ' results in a
    Serout2 PORTC.6,16468,[hex AEXP, " ", hex AARGB0, " ", hex AARGB1, " ", hex AARGB2, 13, 10]
  1. Single button function
    Last Post: - 4th April 2020, 19:33
  2. Hash function
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 7th September 2007, 11:09
  3. Making a function to set the DS1337 Alarm in C
    By trw01 in forum mel PIC BASIC Pro
    Last Post: - 12th February 2006, 18:45
  4. ATAN2(,) function
    By vk2tds in forum PBP Wish List
    Last Post: - 25th November 2005, 03:52
  5. Random function - How to limit it ??
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 30th November 2004, 15:05
