clock/timer calculations
Results 1 to 3 of 3
    Jan 2007
    Red face clock/timer calculations
    Hi to all,
    I am a novice in programming but I wish to design a 24-hour Clock/Timer that it could switch a relay alternatively on and off during two to four programmable periods, for instance:
    1.- 06:00 to 10:00 on
    2.- 10:00 to 14:30 off
    3.- 14:30 to 22:00 on
    4.- 22:00 to 06:30 off
    Obviously, the fourth period is between two different days. I thought it was very easy with a 16F628A, a DS1307 and PICbasic but I have stopped in the PICbasic's subroutine to control when the clock is in the fourth period.
    Please, any suggestion?
    Happy New Year
    Virolay
    Quote Originally Posted by virolay View Post
    Hi to all,
    I've got one of these.
    It's called a TX-9000a. Check the first link on a Google search...
    http://www.google.com/search?hl=en&q=tx-9000a
    Got it at Menards for $30.
    Just use OR instead of AND.
    For simplicity, IF you were only using the Hours.
    IF (RTChour >= 6)  AND (RTChour < 10) then INperiod_1
    IF (RTChour >= 10) AND (RTChour < 14) then INperiod_2
    IF (RTChour >= 14) AND (RTChour < 22) then INperiod_3
    IF (RTChour >= 22) OR  (RTChour < 6)  then INperiod_4
    HTH,
  1. CRC Calculations
    By timmers in forum mel PIC BASIC Pro
    Last Post: - 16th June 2009, 18:10
  2. Incorrect calculations... please help.
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 29th January 2007, 23:03
  3. Floating Point calculations in PBP
    By uuq1 in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 16:08
  4. Calculations for using faster Clocks.
    Last Post: - 18th April 2005, 15:24
  5. timing calculations
    By scorpion in forum mel PIC BASIC Pro
    Last Post: - 28th November 2004, 23:58
