Ok. No matter what your source is, bat or line power. You need to measure the current flow so, it is easier to do it before your regulator. In this case you do not mess with the output voltage regulation and everything is much simpler.
Of course this has the drawback that measurment would include also the regulators own consumption. But if you know it, then it can be subtracted or do not bother at all if it is << that output current.
I have to state that I tried that way and because of the components needed, a one chip solution is much more accurate, elegant and is working either at + or ground rail. But then, it is just me!
