Hi zerosvarka, Heat sink looks better, should be Aluminium or Copper, steel is a poor conductor of heat. You should have somewhere for that big old spark to go, put a plug wire into it attached to a sparkplug and ground the plugs outer shell, think where is the spark going now, if it flashes over to the side the transistor is on it's time to practice replacing it again. ! more thing, the coil looks like a used unit, how much current is the primary pulling, and do you have a current limiting resistor in the primary circuit?
