Colect data from rs232
Results 1 to 13 of 13
    nah it works... depending how you send your data.
    look how a excel table is made, Line/Column right?
    paste this one in notepad, then import it in excel
    COLUMN1	COLUMN2	COLUMN3	COLUMN4
    0X00	0X01	0X02	0X03
    0X10	0X11	0X12	0X13
    0X20	0X21	0X22	0X23
    0X30	0X31	0X32	0X33
    Here i used space, you can use space, comma, semicolon
    Now it should give you some light!
    OK guys,
    i know now were i missed.
    You have to give me credit...this is not my native language
    "Carriage return after every data reading instead of a comma"
    So... if have something like :
    debug ",",#va ( using comma to separate each value )
    i should have:
    debug #va, $13 ( being 13 hexa code for carriage ) ?
    EDIT: 13 for ascii and 0D for hexa.
    But what i get is this :
    777777777777
    ( between each 7 i get a square simbol )
    euh.. it's decimal 13 not hexa 13, and it's usual to add a LineFeed , decimal 10.
    So try
    DEBUG DEC VA,",",13,10
    and you should be in business.
    Try this using MicroCode Studio Serial Communicator. From there you can also save the Received window as a TXT file.
    If you did your own VB code, and place your text in a textbox, you have to enable it's multi-line poprietie... unless it might screw things.
    As Steve noted, your data should be in ASCII format. So if your variable contains zero, you should send the ASCII zero, that is 48 decimal or 30 hex.
    That is what the DEC is doing in the Steve's example.
    Hope it is clear now.
    And I think the extra comma is not needed before CR.
    euh yeah... mixed few things here. if there, it won't screw things.. it's just not needed
    Thanks alot guys,
    i did some experiments yesterday and i used the method:
    DEBUG DEC VA,13 with no result... i needed the extra 10 there at the end
    Steve, will try the :
    DEBUG DEC VA,13,10
    that you mentioned and give some feedback later.
    PS.: I'm currently using the RS232 Data Logger from Eltima ( which is freeware ) to colect the data and save to a txt file.
    Hi all,
    it works as it should
    You guys are the best
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
