Bootloader for 16f87/88 that doesn't use UART
Results 1 to 34 of 34
    Feb 2003
    Sydney, Australia
    Default Major Issue !!
    Hi Guys,
    based on what I found in http://www.picbasic.co.uk/forum/showthread.php?t=4498 I set about modifying the PBPPIC14.LIB to move the library functions out of the low memory so we don't overwrite them when we upload a new programme. I was getting compilation errors about not being able to move the librarys off page 0, but commented out the warning section to see what happened.
    Well the answer was - nothing. The programme appeared to not start (I have some LEDs to give me status). I set the library to start at 800 using a custom Make_Loader define that I had in my BL program and it works again.
    Custom Define definition from PBPPIC14.LIB
    <code>
    ifdef MAKE_LOADER ; Added by Bill Coghill 08.01.08
    LIST
    ORG 800 ; Keep the library code out the way
    NOLIST ; was 3584, but would then not work
    </code>
    So it looks like we can't move the PBP libary files out of page 0 which means that we either need to see if we can jump over them with an ORG 128 (or similar - remember we can only erase blocks of 64 words).
    What I need to do is see how big the PBP libraries are when I use an ORG to move the actual program code to high memory.
    I wonder if only the Librarys that are used are compiled in ? That would mean if I was to use the bootloader with a skip over the libraries to upload a file that didn't use a library that the Bootloader needed that the next time you tried to go to bootloader mode it would hang the chip.
    Just did a quick test and it seems that 153 words are needed for the library functions. But more testing reveals that PBP compiles in the Libs it needs, meaning that the value for the libs may change according to the commands used.
    Oh dear and it was all going so well. I need to think about where we can go now.
    We might end up loosing a lot of space as a skip at the beginning for the Libraries and 400 words for the BL at the end !!
    bill.
    Mar 2006
    China
    Default So you found the link :-)
    Well,
    http://www.picbasic.co.uk/forum/showthread.php?t=4498 works.. but the hack you tried doesnt. The only way I have gotten this to work is to (as stated later in the thread)
    ifdef LOADER_USED
    LIST
    ORG 60160 ; Own loader address depending how big loader you write
    NOLIST
    And if you first write your bootloader and then you can change the address from where it starts to allocate just as much memory as it needs. By putting the bootloader last in the program space you also get less trouble with interupt vectors if you are using a 18-pic with high and low priority interupts. This is an ugly hack and dont forget to change back these things when you plan to compile your normal software.
    /me
    Feb 2003
    Sydney, Australia
    Jumper,
    It seems the 16 series pics are different in how the libraries are assigned in memory space. I am going to look further in to it, but will try to mod the LOADER_USED jump as suggested.
    stay tuned..
    bill.
    Feb 2003
    Sydney, Australia
    Unhappy Show stopping issue
    Well I did a bit more digging and talked to Jeff at MELabs.
    This is what he told me :
    <quote>
    Jeff Schmoyer wrote:
    Hello,
    The problem is that you really can't do that. For the 14-bit
    core parts, the library must be at the bottom of memory. The
    bootloader has to be a completely separate program, including
    its own library. This really isn't practical for a 14-bit
    core part.
    We did make a change for the PIC18 parts to allow the reset
    location to be changed. This allows you to move the library
    and the entire program up to higher memory. When you
    boot load in a new program, it fills in at the bottom as
    usual, with the bootloader and its library still up high.
    For the 14-bit core parts, you will need to create an
    assembler boot loader that does what you want, or modify
    one of the many that are already out there.
    To write one in PBP, you will need to move to a PIC18 part.
    Thank you,
    Jeff Schmoyer
    microEngineering Labs, Inc.
    </quote>
    So it looks like it is back to reverse engineering other peoples ASM code to make it run in the 16F87. I am now going to look at the WLoader ASM and see how 'portable' it is to the 16F8x series.
    Stay tuned...
    bill.
    Sep 2005
    Campbell, CA
    This might be a silly question, but why not move to 18F parts and solve the problem that way?
    Charles Linquist
    Feb 2003
    Sydney, Australia
    Hi Charles,
    I looked into using something like the 18F1320, but the HW UART pins have moved, which means a redesign of the PCB.
    Wehn the product comes up for a design refresh I will look at moving to a new processor, but for now looks like I am stuck with the 16f87.
    All is not lost as I think I can re-engineer the WLoader to work.
    bill.
    Quote Originally Posted by bcd View Post
    You using DIP or SOIC?
    If DIP, put one in a socket, pop out some pins and run some jumpers.
    Not the best fix in the world, but works for me.
    If SOIC, maybe cut some traces and run some jumpers.
    Same thing, not the best, but it works.
    Dec 2005
    Quote Originally Posted by Charles Linquis View Post
    In my case, I want to use the internal comparators as inverters for the UART and I haven't found an 18F PIC in the same size range as the 16F88 that will let me do that.
    Feb 2003
    Sydney, Australia
    Still looking in to this and I think I have found a way. Using the SparkFun BLoader code and a quick tutorial on bit-banged serial ports in C I am aiming to do a bit of testing this weekend.
    Not as nice as a pbp based one, but if it works - woohoo !
    bill.
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  4. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
  5. Replies: 3
    Last Post: - 26th January 2005, 14:41
