Bootloader for 16f87/88 that doesn't use UART
Results 1 to 34 of 34
    I'd offer to help squish but fear I'd squash. Once squished, I'll provide PureBasic source for Windows/Linux/Mac interfaces. I can test Windows & Linux but don't have a Mac. PB code is fairly easy to convert to VB.
    Generic question about bootloaders...since I haven't had the need to use them.
    Do the bulk of the bootloaders out there do HEX files or straight binary data (assuming you're not ever changing the config registers, IDLOCs, etc.)...
    Dec 2005
    I think most, if not all, handle hex files.
    i'll second the .HEX. Anyways.. what's the point of .BIN file while none of the assembler i know generate it anyway
    Feb 2003
    Sydney, Australia
    Wow ! What have I started !
    dhouston - i was aiming to take the freeware delphi source from the PIC_E project, as I hate the way VB projects seem to bloat. But looking into the source it has a checksum and some other funky stuff I don't think we need. It has also been a long time since I did any delphi stuff and I might be out of my depth. Is PureBasic a good coding app - I have never heard of it before.
    mister_e - agreed .hex is the way to go. F10 in MCS to the unit. Hmmm - there is a thought - can we pass command line options to it for the name of the hex file ??
    i have been thinking about other thinks that would be good and I am looking into the ability to also write the internal EEPROM. I have disected the INTEL HEX format and worked out which data points to which locations and it looks like it should be quite easy (famous last words...)
    bill.
    Dec 2005
    Quote Originally Posted by bcd View Post
    It's excellent. It's inexpensive. It's cross-platform. It compiles to teensy-weensy standalone executables. It's been a well kept secret. Here's the homepage - http://www.purebasic.com/
    If you can supply easy to understand documentation, I'm willing to code the interface apps.
    Feb 2003
    Sydney, Australia
    Default Major Issue !!
    Hi Guys,
    based on what I found in http://www.picbasic.co.uk/forum/showthread.php?t=4498 I set about modifying the PBPPIC14.LIB to move the library functions out of the low memory so we don't overwrite them when we upload a new programme. I was getting compilation errors about not being able to move the librarys off page 0, but commented out the warning section to see what happened.
    Well the answer was - nothing. The programme appeared to not start (I have some LEDs to give me status). I set the library to start at 800 using a custom Make_Loader define that I had in my BL program and it works again.
    Custom Define definition from PBPPIC14.LIB
    <code>
    ifdef MAKE_LOADER ; Added by Bill Coghill 08.01.08
    LIST
    ORG 800 ; Keep the library code out the way
    NOLIST ; was 3584, but would then not work
    </code>
    So it looks like we can't move the PBP libary files out of page 0 which means that we either need to see if we can jump over them with an ORG 128 (or similar - remember we can only erase blocks of 64 words).
    What I need to do is see how big the PBP libraries are when I use an ORG to move the actual program code to high memory.
    I wonder if only the Librarys that are used are compiled in ? That would mean if I was to use the bootloader with a skip over the libraries to upload a file that didn't use a library that the Bootloader needed that the next time you tried to go to bootloader mode it would hang the chip.
    Just did a quick test and it seems that 153 words are needed for the library functions. But more testing reveals that PBP compiles in the Libs it needs, meaning that the value for the libs may change according to the commands used.
    Oh dear and it was all going so well. I need to think about where we can go now.
    We might end up loosing a lot of space as a skip at the beginning for the Libraries and 400 words for the BL at the end !!
    bill.
    Mar 2006
    China
    Default So you found the link :-)
    Well,
    http://www.picbasic.co.uk/forum/showthread.php?t=4498 works.. but the hack you tried doesnt. The only way I have gotten this to work is to (as stated later in the thread)
    ifdef LOADER_USED
    LIST
    ORG 60160 ; Own loader address depending how big loader you write
    NOLIST
    And if you first write your bootloader and then you can change the address from where it starts to allocate just as much memory as it needs. By putting the bootloader last in the program space you also get less trouble with interupt vectors if you are using a 18-pic with high and low priority interupts. This is an ugly hack and dont forget to change back these things when you plan to compile your normal software.
    /me
    Feb 2003
    Sydney, Australia
    Jumper,
    It seems the 16 series pics are different in how the libraries are assigned in memory space. I am going to look further in to it, but will try to mod the LOADER_USED jump as suggested.
    stay tuned..
    bill.
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  4. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
  5. Replies: 3
    Last Post: - 26th January 2005, 14:41
