The routines Dave posted are a good place to start, and he has a lot more interesting tutorials on his site. Definitely worth a visit.
But, you can definitely send/receive serial data without using encoder/decoder ICs. If you do, you'll want to packetize your data, and probably use a preamble, synch byte, redundant data, and maybe even a checksum.
I use these with serout2/serin2 all the time, and it works exceptionally well, but you do have to learn to deal with noise, and data errors.
You can also develope your own protocol using pulsin at the receiver, and simply taking the transmit pin high/low for specific periods to transmit.
It's pretty easy once you've had time to experiment with different methods. Which one works best normally depends on the application. The more critical the data, the more work it is to send/receive it reliably.
We carried stock of 315MHz, 418MHz and 434MHz TWS/RWS for several years. We had a hard time keeping the 434MHz versions in stock. The 315MHz and 418MHz versions sat there forever. That's the only reason we dropped them.
