NEWB Help HPWM coding
Results 1 to 4 of 4
    I'm not sure how this works, but when I compile the code with Proton_DS_Lite is compiles without errors.
    Can someone explain this to me please?
    /Michael
    well, because
    1)PBP don't have PRINT but LCDOUT,
    2)PBP don't allow to use LOW as Variable, should be the same with PDS
    3)PBP don't use DEC to decrement a variable, not sure in PDS
    4)PBP don't use INC to increment a variable, not sure in PDS
    5)There's no DelayMS in PBP but PAUSE
    6)REVERSE is a reserved word in PBP
    Now if you use PDS, we can't really help, www.picbasic.org/forum will.
    you may try this one...
    WHILE 1 = 1 'Infinite loop
        IF S1 = 0 THEN
            IF SPEED = 0 THEN DIRECTION = REVERSE 'If motor stopped, set reverse direction
            IF DIRECTION = REVERSE THEN 'If engine in reverse, then..
                IF SPEED < 255 THEN
                    SPEEED= SPEED +1 'If Speed less than Maximum, then increase
                ELSE 'Else goto FORWARD loop
                    IF SPEED > 0 THEN
                        SPEED = SPEED -1 'If speed not yet 0, then decrease speed
        IF S2 = 0 THEN 'If S2 pressed, then
            IF SPEED = 0 THEN DIRECTION = FORWARD 'If motor stopped, set forward direction
            IF DIRECTION = FORWARD THEN 'If engine in reverse, then..
                IF SPEED < 255 THEN
                    SPEED=SPEED+1 'If speed not yet 255, then increase speed
                ELSE 'Else goto REVERSE loop)
                    IF SPEED > 0 THEN
                        SPEED= SPEED-1 'If speed not yet 0, then reduce until 0
        FORWARD = DIRECTION 'As DIRECTION = HIGH then
        'FORWARD = HIGH
        REVERSE = ~FORWARD 'REVERSE is negated to FORWARD
        HPWM 1, SPEED, 2000 'Alloctae 'SPEED' value to the CCP module
        PRINT AT 1, 13, DEC (SPEED * 100) / 255, "% " 'Reflect speed in %
        DELAYMS 10 'Increase SPEED
        IF SPEED = 0 THEN
            DELAYMS 700 'Wait longer when speed =0
        WEND 'To While
    HTH
    thanks for your help, greatly appreciated.
    I will look through your changes to understand what you did
    /M
  1. HPWM coding
    By civictypeR in forum mel PIC BASIC Pro
    Last Post: - 29th January 2008, 14:54
  2. need help on hpwm
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 15:49
  3. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:05
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 14:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
