I/O extender
Results 1 to 18 of 18
Thread: I/O extender
    Oct 2007
    The Netherlands
    There is a newer version from microchip: MCP23017
    It has an internal oscillator, no external C and R needed, also the pin layout is a bit nicer. I also had problems getting a MCP23016 to work reliably, finally it worked best without any timing C connected.
    Jun 2006
    Exclamation Please clarify...
    Thanks, i'll try MCP23017.
    I know what going on wrong with the code...
    3 things been observed :
    1. I do not put "$" to determine the address in HEX
    2. Before initializing MCP23016, it need to have short delay ( i use 50ms ) otherwise the whole program will not work.
    3. The code should be I2CWrite SDA,SCL,Address,CtrlDir1,[00] not I2CWrite SDA,SCL,CtrlDir1,Address,[00]. This is confusing because the manual shows the address come after Control, but it does not work.
    It works fine after the correction.
    I need help to evaluate my second code.
    I use GP1 as input and GP0 as output.
    However this is what happened :
    Input Triggered | Output Respond
    GP1.0 | No Respond
    GP1.1 | GP0.0
    GP1.2 | GP0.1
    GP1.3 | GP0.2
    GP1.4 | GP0.3
    GP1.5 | GP0.4
    GP1.6 | GP0.5
    GP1.7 | GP0.6
    GP0.7 never respond at all.
    Anyone can help ?
     INCLUDE "modedefs.bas"
    '*****STARTUP*****************************************************************
    TRISA=%00000
    TRISB=%00000000
    '*****PORT Setup**************************************************************
    SDA VAR PORTA.1		'O Serial Data
    SCL VAR PORTA.2		'O Serial Clock
    '*****Constant****************************************************************
    CtrlRW1 CON 00	'Set1
    CtrlRW2 CON 01	'Set2
    CtrlDir1 CON 06	'Set1
    CtrlDir2 CON 07	'Set2
    '**VARIABLES******************************************************************
    Address VAR BYTE	'Address size
    Set VAR BYTE		'Temporary place to put Data
    Address=$40			'Set MCP23016 address as 01
    Set=$00				'Clear Temporary Storage
    '*****INITIALIZING MCP23016 **************************************************
    	Pause 50
    	I2CWrite SDA,SCL,Address,CtrlDir1,[00]	'Set as Output
    	Pause 10								'Delay 10ms
    	I2CWrite SDA,SCL,Address,CtrlDir2,[$FF]	'Set as Input
    Start :
    	I2CRead SDA,SCL,Address,CtrlRW2,[Set]	'Read from input, put in Set
    	I2CWrite SDA,SCL,Address,CtrlRW1,[Set]	'Write data into Set
    	GoTo Start
    Cheers,
    mychangl
    "The Dream Is Everything"
    Oct 2007
    The Netherlands
    What values do you use for the timing R and C? I also had problems with some of the bits not reading well, finally I used 3900 Ohms for the resistor and no C at all. Also you could try to add this line: DEFINE I2C_HOLD 1 (see pbp manual), it worked for me when I increased the clock speed of my pic to 20MHz.
    Jun 2006
    Default Thx
    Surprisingly, it works when i removed the capacitor. Resistor remains 3.9K.
    The code also works fine with or without the capacitor.
    Thanks again..
    Cheers,
    mychangl
  1. PORTA Logic - Be the processor
    By Darrel Taylor in forum FAQ - Frequently Asked Questions
    Last Post: - 9th March 2009, 19:18
  2. I/O dilemma
    Last Post: - 6th January 2008, 17:45
  3. MCP23016 I2C serial I/O expander chip
    By GeoJoe in forum Serial
    Last Post: - 31st October 2007, 16:39
  4. 16F877 universal PCB with I/O module
    By cupajoe in forum Schematics
    Last Post: - 3rd September 2005, 14:39
  5. managing the I/O ports of the 16F84A
    By skyler_91600 in forum mel PIC BASIC
    Last Post: - 28th April 2005, 04:52
