Help needed with Select Case?
Results 1 to 9 of 9
    Bombay, India
    Change this type of code to
     Case "1"		  ' sets A var to 1 if 1 is pressed and If-Then below is correct..
     IF (A=0) AND (B=1) AND (C=1) AND (D=1) AND (E=1) AND (F=0) AND (G=1) THEN A=1
    '1st # in the correct sequence --- 2 = B
     Case "2"		  ' sets B var to 1 if 2 is pressed and If-Then below is correct..
     IF (A=0) AND (B=0) AND (C=0) AND (D=0) AND (E=0) AND (F=0) AND (G=0) THEN B=1
    to this type of code throughout the case structures.
          A=1
         B=1
    Sep 2007
    USA, CA
    Two things to try... first, don't convert your dtmf_digit value to a string (ascii) value. (And if you must, then use a second variable to put the result in.) If you did this just to make the code more readable, then use constants in your CASE's. This, at the least, will allow you to eliminate a code-hungry command.
    Second, if those vars are all bits (and it does look like it) then put them all in one byte, and compare byte values. So, instead of seven compares, you only have one that's efficient and easy to read ... and you can use constants for them, too...
    Case 1   'note it's a byte, not a string
        if bByte_Values = %00111101 then
          bByte_Values.6 = 1
    Case cdtmf_value_2    'note the constant.
        if bByte_Values = 0 then  'can replace BV compare value with constant like cBV_dtmf_2
          bByte_Values.1 = 1
    'etc...
    Hiya Jessey.
    Combination recognition?
    Seems like I've been down this road before.
    Well, ... I'm not going to try to fix what you have.
    I'd suggest highlighting the entire area, and press Delete.
    Much easier ways to go about it.
    Although the text of this post only partially applies to your case,
    I think the code example is more like what you want.
    https://www.picbasic.co.uk/forum/showthread.php?p=32566
    There are several other examples in that thread too.
    HTH,
    jessey's Avatar
    jessey Guest
    Default Thanks
    Happy New Year everyone!
    Thanks so much tenaja, Jerson & Darrel
    Hi Darrel,
    Your code sure looks good, I can't wait to try it out. I'm at a friends place visiting for a while so I can't try it out until I get home but it'll be the first thing on my to do list.....
    Thanks Again
    jessey
    combocount VAR BYTE
    Enter_Access_Code:
    	select_dtmf = 1	          ' Enable the data output from the MT8870
    	Pause 1		          ' Pause 1 mS to let data settle
    	dtmf_digit = (PORTB >> 4) ' Read the top nibble of PORTB for DTMF data
    	' Use LOOKUP to change the DTMF data to an ASCII character
    	LookUp dtmf_digit, ["_1234567890*#ABCD"], dtmf_digit
    dtmf_wait2:
    	IF dtmf_ready Then dtmf_wait2	' Loop here until DTMF signal stops
    	select_dtmf = 0			' Disable the MT8870 data output
    ' access code is 2457316
        IF (combocount = 0) AND (dtmf_digit = 2) THEN GoodKey
        IF (combocount = 1) AND (dtmf_digit = 4) THEN GoodKey
        IF (combocount = 2) AND (dtmf_digit = 5) THEN GoodKey
        IF (combocount = 3) AND (dtmf_digit = 7) THEN GoodKey
        IF (combocount = 4) AND (dtmf_digit = 3) THEN GoodKey
        IF (combocount = 5) AND (dtmf_digit = 1) THEN GoodKey
        IF (combocount = 6) AND (dtmf_digit = 6) THEN GoodKey
        combocount = 0     'invalid keypress
    IF k = 0 THEN listen
    GoodKey:
        combocount = combocount + 1
     IF combocount = 6 THEN
        access_code = is_verified
        FreqOut DTMF_out, 500, 800  ' Play 3 tones to confirm to the caller that
        PAUSE 100                   ' the correct access code has been entered
        PAUSE 100
    Thumbs up
    There ya go.
    With no PIC or compiler in front of you .... Pretty good!
    Just a couple comments for when you get home.
    Make sure the program can't accidently "Fall" into the GoodKey routine.
    If it does fall-in, it was a bad key, so you definately don't want to run the GoodKey routine.
    And the example has seven digits.
    IF combocount = 7 THEN have a
    Happy New Year!
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 08:10
  3. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 19:19
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 15:04
  5. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 22:05
