Find the right PIC...
Results 1 to 6 of 6
    SWITZERLAND (french speaking)
    Default Find the right PIC...
    Hello,
    I just toasted my last 16F88...
    This PIC has ADC "Vref+" and "Vref-" ability.
    I was looking for some replacement PIC having the same feature in the MICROCHIP's web site.
    Unfortunately, this feature is not listed (or I can't see it) in the selection table so I need to look at every and each datasheet; this can take a long long time!
    Does anyone know how to find this information quickly?
    Thank you.
    Roger
    Wink
    Hi, Roger
    16F819 i.e.
    also try the 18F1320 ... which is also 16F88 compatible !!!
    Merci Alain et bonne année!!!
    Si jamais, comment trouve-t-on cette info dans la jungle des chips de MICROCHIP?
    Roger
    Talking Happy new year, Roger
    Like in Switzerland ...
    Oooooooooooooooooooooooone taaaaaaaaaaaaaaaaaaaaaaaaaaaaakes the tiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiime to waaaaaaaaaaaaaaaaaaaaaaatch the relevant chapters of the databookS !!!
    or some have a good memory ...
    Coooooooooooooooooooooooooool !
    Will need to get a faster internet connection then
    Merci encore.
    BTW, do I understand the datasheets well if, in the case of the "Vref+" and "Vref-" use, "Vref+" can not be higher than Vdd and "Vref-" can not be lower than Vss? Or does "Vref+" and "Vref-" accept any voltage as long as their voltage difference doesn't exceed 5V?
    Roger
    Each Vref have to be >0 and <Vdd
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  4. Waking a sleeping PIC
    By anj in forum mel PIC BASIC Pro
    Last Post: - 19th May 2005, 02:51
