That line is "not so good" ...
<< TRISB = %11110000 'set portB pins 4, 5, 6, and 7 as outputs >>
but as HIGH and LOW commands turn pins as they should be ...
reminder: 0 for Output 1 for Input ...
No compiling problems for me nor ...
did you try to re-load PbP and MPLAB / OR MCS to their default directories ??? ... did you verify the MPLAB/PBP Paths ??? ...
see here : http://melabs.com/support/mplab.htm
