16f876a Pwm
Results 1 to 6 of 6
Thread: 16f876a Pwm
    Dec 2006
    Thumbs up The Code...
    Here's some code. Thanks for the help!!
    @ device PIC16F876A, hs_osc, wdt_off, pwrt_off, bod_off, lvp_on, cpd_off
    TRISA=%00000000
    TRISB=%00000000
    ADCON0=7
    ADCON1=7
    W VAR BYTE
    TheLoop:
    FOR W=1 TO 255
    PWM PORTB.0,W,1
    NEXT W
    HIGH PORTB.0
    PAUSE 1000
    ' As soon as I start this PWM on PORTB.1, PORTB.0 goes LOW...this is what I need to fix.
    FOR W=1 TO 255
    PWM PORTB.1,W,1
    NEXT W
    HIGH PORTB.1
    PAUSE 1000
    GOTO TheLoop
    Bombay, India
    You don't seem to have the RBPU enabled in your code (OPTION_REG) and also you may not be having external pull ups on the PWM output pins. So, when the PWM code executes, it does the RMW routine and PortB.0 goes low. You could check on this.
    JF
    Dec 2006
    Smile Fixed!
    That did the trick! Thank you so much!
    Hainkm
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  4. Pwm 16f876a
    Last Post: - 19th September 2006, 07:35
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
