16f876a Pwm
Results 1 to 6 of 6
Thread: 16f876a Pwm
    Dec 2006
    Question 16f876a Pwm
    Ok, I've done PWM a bunch of times on other PICs, but for some reason I can't get the 16F876A do what I want...
    I want to use software PWM, basically doing an RGBW LED Fade (4 channels)
    Right now, using either PORTA or PORTB, I fade up an LED, then set it HIGH. I go to fade up the 2nd channel and the first channel (set high, not using PWM anymore) goes dead.
    I have my pins set to outputs, a/d is off, etc.
    Any ideas?
    Thanks!
    Hainkm
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    >> any ideas?
    R-M-W problem? ... post your code and you will get more help
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Bombay, India
    Paul is right. If you are modifying the outputs like this
    PORTB = PORTB + $2
    You can be sure that bit corresponding to $2 will come on, but the bits which are supposed to stay where they are may not. This is the Read-Modify-Write issue Paul is talking about. Read more about it in the datasheets
    JF
    Dec 2006
    Thumbs up The Code...
    Here's some code. Thanks for the help!!
    @ device PIC16F876A, hs_osc, wdt_off, pwrt_off, bod_off, lvp_on, cpd_off
    TRISA=%00000000
    TRISB=%00000000
    ADCON0=7
    ADCON1=7
    W VAR BYTE
    TheLoop:
    FOR W=1 TO 255
    PWM PORTB.0,W,1
    NEXT W
    HIGH PORTB.0
    PAUSE 1000
    ' As soon as I start this PWM on PORTB.1, PORTB.0 goes LOW...this is what I need to fix.
    FOR W=1 TO 255
    PWM PORTB.1,W,1
    NEXT W
    HIGH PORTB.1
    PAUSE 1000
    GOTO TheLoop
    Bombay, India
    You don't seem to have the RBPU enabled in your code (OPTION_REG) and also you may not be having external pull ups on the PWM output pins. So, when the PWM code executes, it does the RMW routine and PortB.0 goes low. You could check on this.
    JF
    Dec 2006
    Smile Fixed!
    That did the trick! Thank you so much!
    Hainkm
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  3. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 07:24
  4. Pwm 16f876a
    Last Post: - 19th September 2006, 06:35
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 00:26
