programming PICs in circuit
Results 1 to 2 of 2
    Default programming PICs in circuit
    Hello Everyone. I have a PCB with a 12F629 plugged into an 8-pin IC socket on it. All GPIO's are tied to VSS (ground) through a 47K resistor network. At this point there are no other connections to the ports and all 8 pins are readily accessable with an 8-pin connector. Is there an easy way to program the chip with my HEX file without having to remove it from the socket, put it into the programmer & then replacing it into the socket? Thank you.
    hi,
    of course you can do it in circuit have a look here
    http://microengineeringlabs.com/support/icsp.htm
    next step for you is to get the exact pin # of your chip PGD,PGC,MCLR,VSS and to jump them to your favorite programer with a header. Once it is program, remove header.
    Usually i use DIP socket on the programmer + flat cable + male header to insert/remove on Proto-Board.
    The only thing you have to be aware of is the load on PGD,PGC when programming... must be close to open load. usually i use them for push button.
    regards
  1. Simultaneous programming of multiple pics - is it possible?
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 18th April 2010, 05:56
  2. Programming Pins of PICs?
    Last Post: - 15th August 2007, 19:59
  3. Programming Multiple PICs Simultaneously
    By Archangel in forum General
    Last Post: - 16th January 2007, 20:42
  4. In circuit GANG programming?
    By dhouston in forum General
    Last Post: - 13th February 2006, 01:43
  5. In circuit serial programming
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 17th February 2005, 16:08
