Internal eeprom - erase block
Results 1 to 33 of 33
    Use a STOP or an endless loop before the END statement.
            pause 2000
            lcdout $fe,1,"Successful!"
    Here:   GOTO Here
    Nov 2007
    Cebu, Philippines
    Default thanks
    Thanks steve.
    I'll try this.
    Nov 2007
    Cebu, Philippines
    Unhappy Still won't work
    Hi Steve!
    I placed an endless loop before the END, but still i got the same output.
    What should I do?
    Please help...
    Nov 2007
    Cebu, Philippines
    Default error in my code
    Hi skimask!
    The DEC code will cause a compilation error.
    What shall I do?
    If you know other means please tell me...
    Thank you in advance.
    Quote Originally Posted by ria_river View Post
    Hi skimask!
    What shall I do?
    What shall you do?
    Read the manual, figure out how to use it for yourself.
    Jeez...try to do some of the legwork yourself for a change...
    I know of plenty of other 'means' to do what you want, but you want to be spoonfed like a little baby...
    Unless of course you don't have a manual because you've got a pirated copy of PicBasicPro.
    Which is entirely possible.
    You know that online PDF at MeLabs website isn't exactly up to date.
    Nov 2007
    Cebu, Philippines
    Smile I see
    Thank you for all the help.
    I been reading the manual a lot of times. I even follow the codes and procedures provided by the manual.
    It's just simply won't work.
    Again, thank you very much for your time and ideas.
    Nov 2007
    Cebu, Philippines
    Post me again
    Hi everyone!
    I can read and write now using the pic16f84a but I can't do that using pic16f877a.
    Is there any lines I have to add inorder to allow reading and writing the eeprom?
    I've read the 16f877a datasheet. It is stated there that I have to disable all interrupts before writing. I've tried that but still won't work.
    A working simple code for reading and writing the internal eeprom of pic16f877a is all I need.
    Please help me...
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. config bits
    By brianD in forum mel PIC BASIC Pro
    Last Post: - 9th February 2010, 13:45
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 15:26
  5. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 19:42
