Internal eeprom - erase block
Results 1 to 33 of 33
    Jan 2006
    Istanbul
    Quote Originally Posted by BrianT View Post
    What this is saying is that the first 4k locations are 'high endurance' (and probably physically larger). The remaining 28k bytes are 'standard endurance'.
    Just make sure your code always starts to store data from address 0 so the low adfdresses get most writes and the highest see less writes.
    HTH
    Brian
    Hi Brian,
    What it says is clear.
    The thing is, for standard block, it says 1M cycle at the beginning, but 100K cycle at the end of the statement. Read it again!
    Nov 2007
    Cebu, Philippines
    Default read eeprom problem
    Hi everyone!
    I'm using PIC16f877a and I program it this way:
    'PIC DEFINES
    @ DEVICE pic16f877a, XT_OSC
    @ DEVICE pic16f877a, WDT_ON
    @ DEVICE pic16f877a, PWRT_ON
    @ DEVICE pic16f877a, BOD_ON
    @ DEVICE pic16f877a, LVP_OFF
    @ DEVICE pic16f877a, CPD_OFF
    @ DEVICE pic16f877a, PROTECT_OFF
    @ DEVICE pic16f877a, WRT_OFF
    'LCD DISPLAY
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    'DEFINE LCD_COMMANDUS 2000
    'DEFINE LCD_DATAUS 50
    ADCON1=7
    prnt var byte[2]
    TRISB=%00000000
    TRISC=%00000000
    TRISD=%00000001
    CMCON=%00000111
    'CVRCON=%0000000
    OPTION_REG.7=0
    EEPROM 0,[1]
    EEPROM 1,[8]
    lcdout $fe,1,"Reading eeprom"
    read 0,prnt[0]
    read 1,prnt[1]
    lcdout $fe,1,"Reading=",#prnt[0],#prnt[1]
    When I load the hex file I can see the values 1 and 8 stored in eeprom address 0 and 1 respectively.My problem is that it can't read those values. the lcd will just display "Reading=00".Please help me
    Try this for grins, same thing but different...
    loc0 var byte
    loc1 var byte
    write 0,1
    write 1,8
    read 0,loc0
    read 1,loc1
    lcdout $fe,1,"Reading=",DEC loc0,DEC loc1
    Should say "Reading=18" when it's run.
    Nov 2007
    Cebu, Philippines
    Unhappy i'll try
    I also got problem writing the eeprom. I program it this way:
    lcdout $fe,1,"writing the eeprom"
    write 0,2
    write 1,3
    pause 2000
    lcdout $fe,1,"Successful!"
    The output is terrible.It will just make the lcd display "writing the eeprom" and it will keep on refreshing...
    Please help me...
    Use a STOP or an endless loop before the END statement.
            pause 2000
    Here:   GOTO Here
    Nov 2007
    Cebu, Philippines
    Default thanks
    Thanks steve.
    I'll try this.
    Nov 2007
    Cebu, Philippines
    Unhappy Still won't work
    Hi Steve!
    I placed an endless loop before the END, but still i got the same output.
    What should I do?
    Please help...
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. config bits
    By brianD in forum mel PIC BASIC Pro
    Last Post: - 9th February 2010, 14:45
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 16:26
  5. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 20:42
