I've got stuff for accessing CF cards (IDE mode only) and IDE hard drives. Worked great on my mp3 player...But...I was using SK-OS (skimask operating system), my own tables, my own way of doing things, so it wasn't compatible with anything (even had to wipe the disk completely when I put it back into the laptop).
Using an 18F4620 @ 40Mhz, I was able to move well over 1MB/second across a low speed USB port and almost double that if I was going from master to slave.
I downloaded the 'FAT32' bible written by Microsoft awhile back, read it, figured it wasn't that hard to deal with, just didn't have a need to deal with FAT32.
BUT...now that PBP 2.50 supports 31bit integers, and looking back on it, it should be a LOAD easier to write a FAT32 'library' (not that it was that hard before).
In my mind, the main problem is the lack of direct string handling for filename's. Not really a limitation if a person is willing to write a macro or two to handle that.
Well, that and the lack of the amount of ram on a PIC itself (easily solved by an FRAM chip I supposed)...
