Help! use PBP246 for PIC18F2525
Results 1 to 11 of 11
    Dec 2007
    Angry Help! use PBP246 for PIC18F2525
    We have tried to transfer from PIC16F to PIC18F2525. When we evaluated the PIC2525 with code to diaplay something in LCD,we failed:
    coded in PICBasic ;
    compiled using PBP246+MPLab V8;
    The machine code did not work, there is nothing in LCD, but if we programm in ASM directly,it works.
    And, if we embeded ASM lines into PicBasic lines,it didn't work either!
    We have studied the PBP246 & PIC18F2525 for a long time,but no advance.
    Anyone faced this kind of question too before?
    Any advice is welcome!
    Dec 2007
    Anyone use pbp246 over PIC2525 ?
    Quote Originally Posted by dragon View Post
    Code used in PBP?
    For what i remind, PBP2.46 & PIC18F2525 worked for me. As Skimask says, just post your code here.
    Dec 2003
    Storrs, Ct.
    Default Yes it works.
    I know for a fact it works as I have a display board with 3 MAX6957's burning away right now with an 18f2525@ 20Mhz. I migrated from a 16f876 and had a few setup issues with registers but it went reasonably well.
    Hope this helps..
    "It will never happen here!" just happened here.
    My thoughts and prayers for Sandy Hook victims and families.
    Dec 2007
    Thanks,try once more, if failed I will post the test code.
    Dec 2007
    Default test code
    DEFINE OSC 8
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 4
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 5
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 4000
    DEFINE LCD_DATAUS 100
    CMCON = 7
    ADCON1 = 6
    TRISA = %11000000
    PAUSE 5000
    loop:
    Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Hello" ' Display Hello
    Pause 1000 ' Wait .5 second
    Lcdout "World"
    Goto loop ' Do it forever
    Dec 2007
    it doesn't work! please help! thanks
    DEFINE OSC 8
    DEFINE LCD_DBIT 0
    DEFINE LCD_EBIT 4
    DEFINE LCD_RSBIT 5
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    CMCON = 7
    ADCON1 = 6
    TRISA = %11000000
    PAUSE 5000
    loop:
    Lcdout "World"
    Then study more you must...
    In your case...
    Port A, Bit 0-3 = data bits for LCD
    Port A, bit 4 = e for LCD
    Port A, bit 5 = rs for LCD
    ADCON1 = 6
    According to the datasheet I've got...
    You've set up: ADCON1 = %0000110
    Vref+/Vref- on Vdd/Vss...
    AN9-AN12 = digital, AN8-AN0 = analog...
    Do ya see any important information up there?
    Page 224 of Microchip datasheet DS39626D...
    Dec 2007
    Default thanks! the problem has solved.
    CMCON should be defined correct value.
    Dec 2007
    Thumbs up
    Skimask,Thank you very much for kindly explaination.
