mikroBASIC
Results 1 to 2 of 2
Thread: mikroBASIC
    Hangover, Germany
    Wink mikroBASIC
    Hello,
    I worked the last 2 weeks with this compiler, because there is some work to be done using a mmc with FAT16 and there is no code for pbp around.
    It's a nice compiler with a huge packet of lib-functions for the hardware and even more - but the generated code is ... suboptimal.
    I think, it is a pascal-compiler with a changed syntax.
    If someone want's to enter a new world, just try a look, but the compiler is not without any problems! You must change your way to code.
    You can use functions, but the parameter-handover to the functions needs a lot of code.
    You can use local variables ! - But they don't know bit-arithmetik.
    But without that compiler I have to write my own FAT16-lib...
    PBP 2.50C, MCS+ 3.0.0.5, MPLAB 8, MPASM 5.14, ASIX Presto, PoScope, mE mikroBasic V7.2, PICKIT2
    Default FAT 12, FAT 16 and FAT32 with PBP
    There are other ways to get mass storage card access than converting to another compiler with all the fun and trauma that entails. I have just used the Vinculum VDIP1 with a PIC 18F4620 project. The VDIP1 takes serial data from the PIC and drives the USB interface. The VDIP1 handles the FAT 12, FAT 16 and FAT32. By using a common USB to CF, MMC, SD, etc, card reader you get read and write access to most memory formats.
    In my application I log data from a scientific instrument to a USB stick. I am using the default 9600 bps async uart writing to a 1 GB USB memory stick.
    I have posted the code under the Code Examples section.
    Cheers
    Brian
  1. i cant get 18f2550 work as HID
    By Ahmadabuomar in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 17:39
  2. mikrobasic to picbasicpro
    By nicolasronan in forum mel PIC BASIC Pro
    Last Post: - 6th September 2006, 23:34
  3. Which PBP Compiler are you using?
    By Melanie in forum General
    Last Post: - 24th January 2006, 18:42
