It's impossible to say without knowing the specifications of what you have lying about. I usually recommend the TSOP1100 because it covers carrier frequencies from 32kHz-57kHz.
There are several schematics on the WinLirc (or Lirc if you do Linux) that use minimal hardware with the serial port.
You need to be aware that the RS232 voltage levels are on the order of 12-15V so you need to take steps to limit the voltage but, the answer is yes it can be done.
