"hello world" with 18f6680
Results 1 to 40 of 92
    Apr 2006
    Alberta Canada
    i made the code for this LCD as a seperate file, and just "include"d it into the main program. its actually the first time i have used the include command. now that i think about it, i should make sure i labelled all my ports properly for the display.
    i know there is cheap parrallel displays around that are 2x8 or 2x10, so i might think about one of them...
    ive been thinking about redesigning it and including some other stuff that i would like too. there is going to be a parallax GPS in this project, and i need to do some calculations for directions, so i need to use arctan. i think it might be easier to include a math coprocessor to do the calculations... i would also like to change the voltage regulatorto something that can supply more current, since im using the same supply for multiple things.
    i will probably get this thing going and use it to test all the other "bits" i want to add, then after i have things working, i will make a new design and include more stuff.
    Quote Originally Posted by dragons_fire View Post
    That's the way to do it...handy, quick, not so easy to transport between 2 people and have the other guy understand at first glance...but still good...
    I tell ya what...I love my Nokia displays. 12 (actually 16, but takes more code) bit color, 132x132 (130x130 usable) resolution, 21x15 text (with a 5x7 font), made subroutines for all sorts of graphics, 6 pins (power, ground, reset, select, data, clock). I've got a 'saved search' on eBay all set aside just for the Nokia 3310 compatible displays and I snag one up every time I see a cheap one.
    The only 'problem' with it is when you go to do a full screen refresh. Even with an 18F4620 using the hardware SPI, a full screen refresh takes awhile. I figure I can only get about 2-3 frames/second. But that's redrawing the ENTIRE screen, one pixel at a time.
    Apr 2006
    Alberta Canada
    here is a picture of the top of the board. its a little fuzzy compared to my other pics, but i was too lazy to go downstairs to get more batteries for my flash.
    i should mention that the solder joints are better than they look, and the flux has been cleaned of a little better since that pic was taken.
    the power input is on the bottom of this board, then it goes through the switch and to the buck regulator underneath the LCD, and then the inductor is the black thing on the right. i ordered the wrong ones, when i built this, so i do have smaller, lighter ones now, i jsut havent put them on.
    the segments on the lcd that im having problems with, will work sometimes but not others, so i am going to stick the meter on and see what it says.
    You said you were aiming to build something for an R/C plane?
    I'm wondering how good (bad?) those LCD segments will look at certain angles with direct sunlight behind/beside/in-front-of them...
    Apr 2006
    Alberta Canada
    it seems to appear like a digital watch when "lit" up.. im assuming it should look about the same in light... i don't really know though... if it doesn't work, i will try something else... thats whats good about doing it as a hobby!!! no deadlines and as long as its cheap, i can try different things until i find something i like.. i cant remember now, but i think i got these displays for around $1 each, and then i got a couple that are 2.5 digits ( 1.8.8) and some LED backlights for them for a couple bucks a set too.
    i will try to post a video of what the display is doing.. then maybe someone will have an idea of what is actually happening....
    Apr 2006
    Alberta Canada
    forget the video, i got it working... i had a couple of the ports backwards.. it works good and heres a pic of the lcd with direct camera flash.. it should show up ok in hte sun
  1. 18f6680 N/C
    By mackrackit in forum Off Topic
    Last Post: - 29th April 2008, 21:21
  2. need help with "hello world" in hyperterm
    By ericmiles in forum Serial
    Last Post: - 31st October 2007, 16:08
  3. 18F6680 and portd problems.
    By jkbh in forum mel PIC BASIC Pro
    Last Post: - 6th June 2005, 11:54
