I got a friend who works the border just north of Antler, ND. (southwest of Regina by quite a bit). I'm going to ask him this weekend.
Flux - rubbing alcohol (standard grocery store stuff) and cotten swabs and/or those acid brushes (or just a small stiff paint brush) work wonders. Overnight soaking doesn't help, re-heating the flux with an iron doesn't work. Just good ol' elbow grease.so i got the board working, and it all seems ok, except for my LCD. the LCd im using is a 24-pin DIP. one pin is common, and the rest are linked directly to one segment. i can get it to work somewhat, but sometimes certain segments dont dissapear when they are supposed to, and others dont always appear when they should.. i think maybe its cause the traces are so close together, and i cant clean all the flux off...
What kind of LCD do you have that has 24 pins? Is this one of those 7-segment types?
You should look into the whole Nokia-knock-off LCDs (check www.sparkfun.com). Easy to control, 6 lines from the PIC, 130x130 pixels, and in color. I'm having a blast with mine.
