"hello world" with 18f6680
Results 1 to 40 of 92
    Apr 2006
    New Hampshire USA
    Talking posting your “problem code”
    skimask’s method is perfect for his style of programming.
    as Joe said: “people, who know the subject material very well”
    But if anyone wants the forum to help with their code (skimask never needs help), I wouldn’t advise posting your “problem code” in this style.
    -Adam-
    Quote Originally Posted by Pic_User View Post
    -Adam-
    'taint so!
    I think the main difference is in the use of the 'Search' function here and at Google, or wherever...I'd be willing to bet I spend more time researching HOW to do stuff vs. actually doing it.
    And this weekend, I could sure use some help doing some sanding, and in fact, I might even need help cleaning out all of those left over full cans of preferred beverages from the 'fridge in the basement...
    Apr 2006
    Alberta Canada
    i would come give you a hand, but "unfortunately" i dont have a passport!!! and i have to wait for Puralator to deliver more parts!!!
    Quote Originally Posted by dragons_fire View Post
    Passports? I thought all we needed was photo Gov't ID. I'd better do some checking. I've got a trip planned for this summer...here, thru the Black Hills/Rapid City, over to Yellowstone/Grand Tetons, up to Glacier (both U.S. and Canada versions), thru Banff and Jasper, up to Denali in Alaska, and back, sidestepping thru Yellowknife and back down.
    Apr 2006
    Alberta Canada
    sounds like a good trip... i think to fly we need a passport now, but to drive you just need two pieces of government id..
    so i noticed a while ago that i had shorted one OSC pin to 5v, would that have blown the OSC part of the chip???
    It's all a bit confusing... To get into Canada, I need one thing, to get back into the U.S., I need other things. Gotta do more looking.
    I wouldn't think so, but...you know how far that goes...
    In external modes with crystals, the crystal/resonator is driving a differential amp inside the PIC (variable gain set by the CONFIG registers). I suppose if you had OSC1 driven to +5v and OSC2 driven to ground, you might blow it out (maximum differential = maximum output). Not really sure about that theory though, and surely not about to try it out.
    Apr 2006
    Alberta Canada
    my stuff just got here a couple minutes ago, and so i soldered a new PIC to the board, and it WORKED!!!!
    thanks to all the guys that had suggestions about why it didnt work, but it seems good now.. i just need to solder the top board back on (i was using jumper wires while testing)....
    That only matters if you come from the north!
    Sad but true
    Apr 2006
    Alberta Canada
    Really?? so when we are told that the USA is changing it to the same regulations canada has when you guys try to come up here, its not really true???
    so i got the board working, and it all seems ok, except for my LCD. the LCd im using is a 24-pin DIP. one pin is common, and the rest are linked directly to one segment. i can get it to work somewhat, but sometimes certain segments dont dissapear when they are supposed to, and others dont always appear when they should.. i think maybe its cause the traces are so close together, and i cant clean all the flux off...
    I took it that Joe meant coming into the US from the south. Regulations do not seem to matter here for that. Illegal boarder crossing seems to be encouraged.
    I got a friend who works the border just north of Antler, ND. (southwest of Regina by quite a bit). I'm going to ask him this weekend.
    Flux - rubbing alcohol (standard grocery store stuff) and cotten swabs and/or those acid brushes (or just a small stiff paint brush) work wonders. Overnight soaking doesn't help, re-heating the flux with an iron doesn't work. Just good ol' elbow grease.
    What kind of LCD do you have that has 24 pins? Is this one of those 7-segment types?
    You should look into the whole Nokia-knock-off LCDs (check www.sparkfun.com). Easy to control, 6 lines from the PIC, 130x130 pixels, and in color. I'm having a blast with mine.
    Apr 2006
    Alberta Canada
    the LCD im using is the seven segment type. it had 3 digits and two decimal points. there is 24-pins (one common, 3digits*7segments is 21 pins, and then the two decimal points. im using a 4x20 serial LCD for debugging and showing lots of info, but i would like to have this on top just to show small amounts of info. these things were pretty cheap, so i thought i would try it. and the datasheet shows the pinout but thats about it. they dont have current of voltage ratings, so i tried it on the breadboard and it seems to work at 5V and my meter doesnt show any current. it also seems as though it will "light" up all the way down to .5V (maybe lower but thats as far as i tried). so im thinking i might be getting inductance or a little leakage off of the flux on the traces that are beside each other.
    i was thinking about the nokia lcd, and i would like it, but i wanted to keep this really small and simple. i havent looked at what it takes for code space either.. is it the same as a parallel LCD?? my little 3 digit one takes lots just because i need to tell it to turn on different ports.
    im working on a flight data recorder for my rc airplanes, and i know there are some out there that i could buy for cheaper than i can make (i already have one too), but i would like to make my own. i will try to post a pic when i get home tonight..
  1. 18f6680 N/C
    By mackrackit in forum Off Topic
    Last Post: - 29th April 2008, 21:21
  2. need help with "hello world" in hyperterm
    By ericmiles in forum Serial
    Last Post: - 31st October 2007, 16:08
  3. 18F6680 and portd problems.
    By jkbh in forum mel PIC BASIC Pro
    Last Post: - 6th June 2005, 11:54
