"hello world" with 18f6680
Results 1 to 40 of 92
    Quote Originally Posted by dragons_fire View Post
    GOOD TO KNOW... i learn so much from all of you on here.... i know these PICs say they are static sensitive, but how bad is it?? should i be wearing a strap every time i think about looking at it?? or do i really need to worry about it. i know with the 16f devices i have used, they say they are static sensitive, but i have never worried about it and never had any problems...
    I haven't COMPLETELY blown a PIC up with static...YET! I know how dry it gets where you're at (remember, I'm just a bit south-east of you). My 'shop' is in the basement, usually about 20% humidity in the winter, carpet on the floor, and so on and so on.
    I think, that is, THINK, the worst I've done to a PIC is blow out an output driver or two on a few PICs...and I'm not even 100% sure it was static that did it. Probably from putting them in the socket backwards, etc.
    However, I've heard that the 18F's are quite a bit more static sensitive than the 16F's were, probably due to the smaller gate size on the die...not sure...don't care. As long as I don't smoke anymore, I'm all good...
    Apr 2006
    Alberta Canada
    ok, i was just kind of curious... i get them from Digi-key and they come in a vacuum sealed static bag with one of those little dessicant bags in it and a humidity tester... the 16f ones, come in a little static bag thats just folded over on its self so it doesnt fall out!!
    Apr 2006
    Alberta Canada
    i de-soldered the pic from the board, everything looks good under there... no solder bridges or shorts of any kind.. everything looks good... i ordered another PIC so it should be here on monday and i will try that...
    i wish there was a pin compatible 16f PIC that i could throw in there and see if i could get it to work... then i would know the board is ok...
  1. 18f6680 N/C
    By mackrackit in forum Off Topic
    Last Post: - 29th April 2008, 21:21
  2. need help with "hello world" in hyperterm
    By ericmiles in forum Serial
    Last Post: - 31st October 2007, 16:08
  3. 18F6680 and portd problems.
    By jkbh in forum mel PIC BASIC Pro
    Last Post: - 6th June 2005, 11:54
