Newbie needs help
Results 1 to 10 of 10
    igeorge's Avatar
    igeorge Guest
    Angry Newbie needs help
    I have a piece of working code on the Flash-Lab 77 board. What to do to make the same processor to run on a stand-alone PCB? When I removed the serial cable from my PC to the Flash-Lab, and I reconnected the power, nothing did happen. It looks like the processor is not running. Connecting the serial cable again, solves the problem and the chip will run normal. Please help me to solve this problem.
    Thank you
    Ion
    Lightbulb
    I'm not really sure to understand the problem but can you chack this. Voltage on pin 1... must be 5Volt. This is the reset pin of thi MCU. If not 5 volt add an 10K pull up resistor to the supply line.
    hope this help
    regards
    On your board find the MAX232 IC. close to it you have jumpers. Remove RST one. This maybe the solution.
    regards
    igeorge's Avatar
    igeorge Guest
    I did put the pull up resistor and remove the jumper.
    The CPU plays dead until i connect back the serial cable to the PC.
    What about the voltage on pin 1??? a pure guess remove MAX232 and be sure to have pull up resistor on PIN 1.
    if it's working, try short pin 4 of DB9 to ground.
    Case problem is still there, Bruce know for sure the solution
    e-mail : [email protected]
    regards
    igeorge's Avatar
    igeorge Guest
    pin1 = 5vdc
    The max233 removed ,nothing happen.
    For sure , Bruce will get a call tuesday morning.
    Thank you
    is by any chance you can post whole code you have???
    Question
    or try add
    DISABLE DEBUG
    at the begining of the program
    i try help...
    igeorge's Avatar
    igeorge Guest
    You are a genious.
    Without DEBUG works like a charm
    Thank you
    Ion
    O.K cool. As you say you're a newbie so here's a few explanation.
    The great FLASH-LAB 77 you buy from Reynolds give you all you need to program/debug your program within MicroCode studio Loader. If you don't include this DISABLE DEBUG line, PIC16F877 will try to communicate with MicroCode Studio at his boot time. Since you're "offline" when you disconnect the serial cable, the PIC16F877 is waiting for MicroCode studio command. That's it.
    happy to help you
    a la prochaine
  1. Newbie making an ignition timer
    Last Post: - 5th August 2012, 18:45
  2. Newbie HELP :(
    By TheOne in forum mel PIC BASIC
    Last Post: - 27th March 2009, 18:15
  3. Newbie: Temperature measurements
    By Budda in forum General
    Last Post: - 30th March 2007, 10:56
  4. PIC Newbie
    By azmax100 in forum Schematics
    Last Post: - 23rd February 2007, 05:52
  5. request for a newbie forum
    By nimonia in forum Forum Requests
    Last Post: - 20th May 2006, 10:01
