PS2 Keyboard not funny !!
Results 1 to 2 of 2
    Jul 2005
    Talking PS2 Keyboard not funny !!
    Greetings chaps,
    Yes I have read previous threads on this subject, yes I have tried numerous codes. However, Im really missing something coz the code below only seems to work on laptops. As far as I can see, there aint any difference between PC and laptop PS2. I am using a PIC16F876A @ 20MHZ and 10k pullups connected to SCL SDA lines to PS2. Ultiblade has been kind enough to share his code with me, however, only seems to work on a laptop. Gaaah, this is really bugging me. If anyone can provide some pointers, would be much appreciated.
    Ive tried sending the packet in different ways, as suggested by
    http://www.picbasic.co.uk/forum/show...board+question
    http://www.picbasic.co.uk/forum/showthread.php?t=81
    I have spent waaay too many days on this project without success, now I would really like somebody to give me a bit of a steer. Many thanks in advance.
    Juan (what am I doing wrong ??)
    @ DEVICE HS_OSC,LVP_OFF,BOD_OFF,WDT_OFF 'Sets fuse values on PIC
    INCLUDE "modedefs.bas"
    DEFINE SHIFT_PAUSEUS 50
    DEFINE OSC 20
    ADCON1 = 7
    CMCON = 7
    char var word
    breakcode var word
    clkout1 var portc.3
    dataout1 var portc.4
    a_key con %00001110001 '$1C = 'a'
    h_key con %00011001111 '
    space_key con %00010100101
    esc_key con %00111011001
    F3_key con %00000010001
    redLed var portb.4
    relay1 var portb.5
    breakcode = %01111000011 '$F0
    'a_key con %10001110000 ' $1C = 'a' reverse order
    'breakcode = %11000011110 '$F0 reverse order
    char = a_key
    high relay1
    high redled
    miniLoop:
    high clkout1
    high dataout1
    high redled
    shiftout dataout1,clkout1,4,[char\11]
    pauseus 100
    shiftout dataout1,clkout1,4,[breakcode\11,char\11]
    ' pauseus 100
    ' shiftout dataout1,clkout1,5,[char\11]
    low redled
    goto miniloop
    What i'll suggest you
    1. measure your clock frequency and make sure it met the PS2 requirement
    2. record what's happening when you boot your PC and a regular PS2 Keyboard is attached
    3. make sure you timing is right... and... erm... make the sure than PAUSEUS really needed between your data
    4. go back to step 2 and compare a real PS2 data against what you're sending
    5. carefully read the PS2 protocol and see if you're allowed to use SHIFTOUT AS-IS
    It really looks easier than it is actually... trust me...
  1. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 17:10
  2. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 01:04
  3. PC Keyboard question
    By HatchetHand in forum mel PIC BASIC Pro
    Last Post: - 18th September 2007, 07:03
  4. PS2 keyboard emulator
    By robertg in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 21:40
  5. My wish: AT Keyboard and Mouse commands
    By sayzer in forum PBP Wish List
    Last Post: - 4th February 2006, 09:23
