Mclr As Input Pin?
Results 1 to 8 of 8
    Hangover, Germany
    Angry
    Yes - it's a mistake of MICROCHIP - even the support says, there is a porte.3, but they don't realize to kick the MPASM-kids the ass...
    Sep 2007
    USA, CA
    Make sure to read the ds on this pin. I use the mclr as an input in an application, but wasted one before I learned a trick... make sure to pause for a couple seconds before you change the setting to turn it into an input. If you don't, then you may not be able to reprogram it.
    using a jdm programmer?
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. Microcontroller with 2 way paging application problem
  3. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 14:55
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
  5. I/O pin and MCLR
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 15th July 2004, 11:52
