Mclr As Input Pin?
Results 1 to 8 of 8
    Dec 2007
    Thumbs up
    thanks for your help
    Hangover, Germany
    Thumbs down
    I have tried it too - but the MPASM reports an error when using porte.3 on a 18f2431, he doesn't know the pin !!!
    It's not a PBP problem, it's a Microchip p18F2431.inc file problem. Seems they forgot to add it in their LAT/PORT/TRIS list...
    BUT, erm, erm.. let's see a datasheet quote...
    10.5 PORTE, TRISE and LATE
    Registers
    Note: PORTE is only available on PIC18F4331/
    4431 devices.
    on the other hand...seems they also forgot their own quote
    10.5.1 PORTE IN 28-PIN DEVICES
    For PIC18F2331/2431 devices, PORTE is only
    available when master clear functionality is disabled
    (CONFIG3H<7> = 0). In these cases, PORTE is a
    single bit, input-only port comprised of RE3 only. The
    pin operates as previously described.
    So, just add TRISE/LATE/PORTE to the .inc file and i'm sure it will work
    Hangover, Germany
    Angry
    Yes - it's a mistake of MICROCHIP - even the support says, there is a porte.3, but they don't realize to kick the MPASM-kids the ass...
    Sep 2007
    USA, CA
    Make sure to read the ds on this pin. I use the mclr as an input in an application, but wasted one before I learned a trick... make sure to pause for a couple seconds before you change the setting to turn it into an input. If you don't, then you may not be able to reprogram it.
    using a jdm programmer?
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. Microcontroller with 2 way paging application problem
  3. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 13:55
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
  5. I/O pin and MCLR
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 15th July 2004, 10:52
