Just a quick thought for you ski... properly charging that Battery-Pack is going to be more tricky than you think because the level of discharge across the entire pack isn't going to be constant... because of those taps you're going to be discharging some cells at a greater rate than others. So, if you're going to be charging the entire pack connected in situ, a lot of cells will reach full charge perhaps a very long time before others.
