Ohhh...ok...I get ya now...
Make sure your MCLR is pulled high regardless of the config bit settings and try it again, except instead of waiting a second for the LED to blink, wait for about 2 minutes.
If it blinks in 2 minutes instead of once per second, the PIC is running on the low speed internal oscillator (32khz - 48khz depending on which datasheet for the 628A you look at) instead of the high speed internal oscillator (4mhz nominal).
If that's the case, then, as stated before by others, do a bit of searchin' and learn how to play with config's and fuse settings.
