Don't know what's wrong!
Results 1 to 18 of 18
    If you have not changed the 16F628A.inc then I bet it is trying to use the XT OSC.
    Look at the link I sent before and the data sheet for the correct setting when using the internal OSC.
    It will be something like INTOSC instead of XT.
    Dec 2007
    Hi Dave,
    How does the compiler pick up the *.inc file and where is it originally placed. In assembler there is an “Include” command but in PBP there are not as far as I have seen.
    I will have a look at the PIC datasheet and the link you supplied, thanks!
    The *.inc is in you PBP directory.
    When you compile with Pic Basic it will automatically look there. Or you can do it in your code.
    The link tells how.
    Look at the ASM file made after you compile and you will see the includes.
  1. LCD Showes Some Wrong Letters
    By sbobowski in forum General
    Last Post: - 23rd September 2008, 19:15
  2. Anyone know whats wrong with this code
    By Bonxy in forum Serial
    Last Post: - 9th March 2007, 16:29
  3. ADCIN - AD settings are wrong
    By teverett in forum mel PIC BASIC Pro
    Last Post: - 4th December 2006, 16:32
  4. What am I doing wrong?
    By mankan in forum General
    Last Post: - 23rd June 2006, 19:03
  5. HDD IDE ATA 2 interface problems. code wrong?
    By rastan in forum mel PIC BASIC Pro
    Last Post: - 27th March 2005, 16:01
