Is it possible for the LAB-XT Telephony Board to communicate with a cell phone?
Results 1 to 3 of 3
    Mar 2006
    Pennsylvania, USA.
    Jessey,
    It is possible by using the serial port on the LAB-XT board and a suitable adapter cable to connect to some cellular phones, but it won't work the same as the land line. A cell phone is basically a digital radio, some you control using Hayes compatable 'AT' commands, others use different methods. You could look at the GSM section of this forum for ideas. (GSM is one kind of cellular network widely used in Europe.)
    As the telephony board includes a lot of example programs I think you will find it much easier to start with a land line and get comfortable with that. You can easily add home automation to your telephony board. The PicBasic Pro manual has a simple circuit for using X-10 powerline carrier modules to turn on lights and small appliances using the Xin and Xout commands, I have my Christmas tree and other lights connected up this way. You can add temperature sensors, etc. with relative ease. I built a small add on board with 8 relays that I can turn on and off using the dtmf (TouchTone) decoder that's already on your board.
    Good Luck!
    Jerry.
    If your oscilloscope costs more than your car...
    jessey's Avatar
    jessey Guest
    Hi Jerry,
    Thanks for the heads up. I live in Western Canada and am not sure if its the same cellular network as in Europe but like you say I have enough to keep me busy with all the sample programs. Its definitely not a high priority but eventually I'd like to explore the possibilities of a message dialer, digital answering machine and a DTMF remote control operated from a cellular phone, now that would be so cool especially in a remote location that doesn't have access to a land line!
    jessey
  1. Making the Lab X1 communicate with the Lab X2
    By MatthewM in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 23:26
  2. Cell Phone
    By elproducts in forum mel PIC BASIC Pro
    Last Post: - 6th October 2004, 02:21
