8mhz internal osc and 455khz
Results 1 to 3 of 3
    Question 8mhz internal osc and 455khz
    Hi there!
    I am trying to create a quick and dirty HPWM SIGNAL AROUND 455khz
    using nothing but the internal, factory calibrated, 8mhz oscillator of a pic16F690.
    (I don't need high resolution duty cycle).
    I believe this could either be done either by:
    1) using prescaler 1:1, pr2 = 3
    and tuning the pic down to around 7mhz using OSCTUNe register:
    10000 = Minimum frequency (8mhz -12% = 7,04 ~ 7mhz)
    2) using prescaler 1:1, pr2 = 4 and using OSCTUNE TO GET
    UP TO AOUND 9 mhz
    01111 = Maximum frequency (8mhz +12% = 8,96mhz ~ 9mhz)
    For some reason I get the feeling I might be missing something though...
    All comments appreciated...
    greetz,
    mike
    Default Bingo !
    Hi, Michael
    Steve's PWM calculator will confirm you an exact 455 Khz @ 50 % duty cycle with 7.28 Mhz clock ...
    http://www.mister-e.org/pages/utilitiespag.html
    Cheers !
    Thumbs up
    Thanks!
    And here some help for others on how its solved:
    Mister E's multi-calc outputs the following for the 8MHz oscillator when we want a 455khz pwm:
    500,0 KHz prescaler1:1 PR2=3 6 Bit resolution
    we want the pwm to be a bit slower so:
    455/500= 0.91
    0.91x8MHz = 7,28MHz
