Bootloader
Results 1 to 10 of 10
Thread: Bootloader
    Default Good but not enough
    Thanks Dear Wolf
    You answered to my question briefly :-)
    I foundout something about bootloader usage. However I need more help. How can I use bootloader in PBP? Can you give me a schematic of way of connection micro and PC?
    As you said bootloader is your favorite way for programming. Is it possible to learm me the way of using?
    Thanks gain
    There's a few different bootloaders here and there (such as TinyBootloader), the one i use is made by Mecanique and come with the full version of MicroCode Studio, the schematic you need to use is like bellow...
    In your PBP code, you just need to add
    DEFINE LOADER_USED 1
    in Microcode studio, you choose MicroCode Loader as programmer.
    Further explanation... http://www.mecanique.co.uk/products/...ootloader.html
    HTH
    Default Tiny Bootloader
    Hi Dear Mister_e
    Thanks for your reply. Unfortunately I haven't MicroCode studio plus and MicroCode loader :-(
    I found Tiny Bootloader- As you mentioned- and downloaded it from here:
    http://www.etc.ugal.ro/cchiculita/so...bootloader.htm
    Have you worked with tiny bootloader? I think that I should write my program with microCode studio ( with--> DEFINE LOADER_USED 1 ) after commpiling send .HEX via Tiny Bootloader. Is it true? Does it work?
    Thaks again.
    Yup make sense to me. now if TinyBootloader utility have it's command line, that would be great 'cause you could launch it directly from Microcode studio as a third party programmer.
    Out of curiosity, which PIC are you going to use? Which OSC speed?
    Default PIC & Type
    Dear Mister_e
    Thanks for your reply. I want to use PIC16F877 and 10 MHz Osc. (Is it possible to use PIC16F628?)
    not suppose to work with a 16F628 as it don't have the capability to write/modify it's own codespace. 16F88 will work.
    Dec 2007
    hi
    mister_e, maybe you remember my problem in the next topic
    http://www.picbasic.co.uk/forum/showthread.php?t=7627
    i am fix my problem usign tinybootloader also, but i have only a waring message,
    when i am load my program usign the tiny, the software say :
    WARNING: PCLATH not initialised before GOTO! ... sucessfully repaired
    and the load continue, and work fine, i am put only DEFINE LOADER_USED 1
    that place i need put this GOTO command for skip this warning??????
    thanks for all
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  4. Bootloader Problems
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 11th February 2005, 18:51
  5. Replies: 3
    Last Post: - 26th January 2005, 14:41
