Pic10f206
Results 1 to 8 of 8
Thread: Pic10f206
    Dec 2007
    Thanks for the help. I figured it was something silly like that. I got the fuses figured out and GP3 now functions as an input like I want it to. However the GP2 pin is set by several registers. We disabled CMCON0 so that takes care of COUT, but leaves T0CKI, FOSC4 is set to 0 in the OSCAL0 register so that should be ok. So if I am correct I need to get T0CS=0. Yes?
    Thanks again,
    Mike
    Yes yes yes
    Dec 2007
    Here is what I am trying do really do with this device:
    <code>
    @ __config _MCLRE_OFF & _WDT_ON & _CP_OFF
    Include "modedefs.bas"
    CMCON0=0
    SI var GPIO.0 'Define serial in pin
    WakePin var GPIO.1 'Define Wake Pin
    B0 var byte
    start:
    low wakepin 'Set the WakePin low
    serin SI,N9600,10,start,b0 'Wait for an interval
    high wakepin 'Set the WakePin High, we got our interval
    B0 = B0 * 60 'Convert the interval to seconds
    sleep b0 'Sleep for the interval specified
    goto start 'Go to "Start"
    </code>
    Bear in mind it's a real nifty PIC, i'll suggest you to use DEBUGIN instead of SERIN. At least @9600 baud with internal OSC, better the chances are to work with DEBUG than SERIN. There's a warning about that in the manual.
    I never tried DEBUGIN/SERIN with 10F though...
    Dec 2007
    So I have been trying to get T0CS=0 in the OPTION register but PBP doesn't seem to under stand "OPTION" as a register name.
    Any ideas?
    Feb 2003
    Salt Lake City, Utah USA
    try OPTION_REG instead of OPTION
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
  1. PIC10F206 - What is the LOWEST Power @ Rest or Sleep
    By rixtalbert in forum mel PIC BASIC Pro
    Last Post: - 18th March 2007, 15:42
  2. Problem with Picbasic Pro and PIC10F202, PIC10F206
    By mikaljan in forum mel PIC BASIC Pro
    Last Post: - 11th May 2005, 22:02
