SD Card Filesystem like AVRDOS for Atmel
Results 1 to 16 of 16
    Pedro Pinto's Avatar
    Pedro Pinto Guest
    Default SD Card Filesystem like AVRDOS for Atmel
    Hello
    Exist a filesystem for sd card for pic's in PBP PRO like the AVRDOS for Atmel Controllers?
    Best regards
    Pedro
    Default VDIP1 Vinculum might do it for you
    Check the Vinculum post in Code Examples.
    HTH
    Brian
    Pedro Pinto Guest
    Hello
    Thanks for the information, but i search a free software solution like the AVRDOS for a non comercial application
    If it not exist i must change for my pain from pic to atmel controllers
    Pedro
    Are you saying that with this AVR-DOS and an ATMEL chip no other hardware is needed?
    Not 100% sure what you're asking, but I think the answer is 'YES'.
    All you need with this DOSOnChip module is a serial connection, whether it's sync- or async, doesn't matter. Set the options and go.
    I tried one out awhile back on a '628A for grins. All I did was dump files on a 1GB SD card to an LCD sequentially. Absolutely no use for the project other than to watch characters scroll by really fast. It worked well. A bit expensive, but it takes a lot of the legwork out of a project requiring mass storage.
    I was going to use it for datalogging on my OBD hookup. Decided against it and went with the larger Dataflash chips and a USB port instead (thanks alot Mr.E, a lot of sleep lost).
    EDIT: Disregard - I missed the point about the AVR-DOS...never mind...I see what you were getting at...
    Dec 2005
    Quote Originally Posted by Pedro Pinto View Post
    Not for PBP but, if you prefer to use a PIC, there is a FAT16 library (I think for PIC18 only) for mikroBasic.
  1. SD or MMC card as storage for logging
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 16th January 2012, 03:07
  2. Replies: 12
    Last Post: - 4th March 2010, 22:20
  3. SD Card file attributes with SDFS3 ?
    By Chris Barron in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 10:18
  4. Writing to SD card
    By dhouston in forum mel PIC BASIC Pro
    Last Post: - 9th November 2007, 12:23
  5. Read and write to sd card
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 28th October 2007, 20:47
