subroutine with hserin
Results 1 to 7 of 7
    Default subroutine with hserin
    Hi!
    My main program calls a subroutine.
    I wonder if the subroutine "ricezione" do not have the answer jumps on "accensione" then exiting from the first subroutine return of this command may be problems?
    gosub ricezione
    goto Main
    ricezione:
    HSERIN 2000,accensione,[WAIT ("+CREG: "),Tm1,Tm2,Tm3]
    depending how "accensione" is made i guess... that snip above doesn't help us
    accensione:
    pause 2000
    power=0
    led=1
    pause 2000
    power=1
    led=0
    Pause 30000
    gosub setup
    goto partenza
    What is the problem if I go out without a subroutine switch RETURN?
    Is it possible to see the whole program?
    Usually for each GOSUB, there's a RETURN
    Start:
            Gosub Somewhere
            Gosub Elsewhere
            goto Start
    Somewhere:
            HSERIN 2000, SomeWhereElse,[DataXYZ]
    SomewhereElse:
            ToGGLE LED
    ElseWhere:
            LCDOUT $FE,1,"Are AZERTY Keyboards still on the market???"
    In Somewhere, if a timeout occure, it jump to SomewhereElse. This is basically a GOTO, BUT you need to use a RETURN to return to Start... or use a variant like...
    Somewhere:
    SomewhereEnd:
    SomewhereElse:
            ToGGLE LED
            Goto SomewhereEnd
    HTH
    Ok
    Thanks for the explanations
    Best regards
    Start:
            Gosub Somewhere
            Gosub Elsewhere
            goto Start
    Somewhere:
    SomewhereElse:
            ToGGLE LED
    ElseWhere:
    Somewhere:
    SomewhereEnd:
    SomewhereElse:
    ToGGLE LED
    Goto SomewhereEnd
    [/code]
    HTH
    Then i can use two examples? The compiler detects if it is a routine principal or if it is a subroutine?
    Both example have to work. Once it hit a RETURN, it remove 1 from the stack level and jump one instruction bellow the last calling GOSUB.
  1. Hserin with Instant Interrupts.
    By ronjodu in forum Serial
    Last Post: - 30th December 2014, 21:17
  2. timeout of Hserin, goto, gosub or both?
    By flipper_md in forum mel PIC BASIC Pro
    Last Post: - 28th October 2009, 19:43
  3. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 01:38
  4. Hserin not working...
    By robert0 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 13:25
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 16:42
