Using a new PIC part no. for the first time is always such an adventure.
Results 1 to 7 of 7
    I know it's a long debate and some have success, some not, but i never suggest to use internal osc for reliable serial comm. BUT you can reduce the baudrate, say 2400 baud, and do some tests.
    Use PICMultiCalc to get the USART settings for you.
    http://www.mister-e.org/pages/utilitiespag.html
    Yours seems to be the good one... just post your code here and maybe we could suggest you few things.
    Mar 2005
    Madison, WI, USA
    Default Calculator and stuff
    Pretty cool calculator. Looks like you have a pretty good handle on DataComm.
    I'm going to retrofit the external osc. tonight and see what happens. I only have two osc. right now that run at 4Mhz. That has always been fast enough on my 16F628A's to get 9600. In my real time application though, 2400 might be enough.
    I refined the code last night and will work on it again tonight, so I could attach it as a .txt file tomorrow.
    Mar 2005
    Madison, WI, USA
    Default External Osc works great
    I found and 8Mhz osc. laying around and put it into the circuit. With the specs. from the baud calculator inserted into the code the code ran first time out giving me accurate I/O from the PC. Now I'm just one pin short of getting 32 outputs. I'll probably be forced to use the input only MCLR as a DebugIn and another one for DebugOut instead of the hardware serial. That would free up C6 & C7 for outputs.
    Thanks for the pointers.
    well, there's always pros and con for using external OSC, if you have many push buttons, you may use the ADC and read from it. a r2r network and ADC can work with at very least 16 push buttons. many many stuff can be multiplexed as well.
    You could also waste your time and try to tweak the internal osc using OSCTUNE... as i said... a REAL waste of time knowing the cons of internal RC osc for reliable timing needs.
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  3. newbe looking for PIC advice
    By Mad Professor in forum General
    Last Post: - 27th May 2009, 08:56
  4. Can a PIC PIC a PIC?
    By afbecker in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 20:55
  5. Linx RF -> HSERIN time delay / time critical app...
    By batee in forum mel PIC BASIC Pro
    Last Post: - 15th October 2004, 16:04
