Wireless problem
Results 1 to 24 of 24
    If you use the example you post, then you will display only the first byte and continue to display that exact byte endlessly.
    If you send serial data then the buffer of the 2-byte long USART will overflow and depending on the setup will stop with error flag raised or replace old bytes with the new ones.
    Please refer to your Data sheet of the PIC you are using for more infos about the USART and its associated flags and control bits.
    If serin/serout work then I am sure that USART will work better and without having PIC to deal with the data untill they are available to process. You must have something wrong with your setup.
    As Steve stated without the whole picture we can only guess.
    Here in Greece we had the ancient times the oracle at Delphi and Pythia making guesses and prophecies but nowadays I suppose it is better to see, measure calculate and then conclude. So if you want real help post all you got (schematics, cablings, software, defines etc).
    Dec 2007
    As the define comment says "continous receive" I guessed it could've be continuos receive in background while pic runs the program, as hpwm.
    I included DEFINE CLROERR 1 to clear overflow automatically.
    And surely I still have to study a lot....
    Dec 2007
    Finally!
    At last I've been able to use USART!
    On the tx side I changed serout from N2400 to T2400 and the rx started to display correct data! Data is sent 10ms after powering the txer.
    99% of data is correctly showed on the display.
    Now I have to mount the sensor and send acquired data along with a sort of checksum.
    I could stay hours watching the display:0...1...2...3...4..... to see if some of my numbers gets lost. Watching it for a minute, no problems!
    So here is the working code for the TX:
    INCLUDE "modedefs.bas"
    ANSEL=0
    CMCON0=%00000111
    define osc 4
    txpin   var gpio.4
    led     var gpio.5
    power   var gpio.2
    i       var byte
    low power
    loop:
        for i=0 to 9
          high power
          pause 10
          serout txpin,t2400,[$55,$55,$55,$55,$66,#i]
          low power
          high led
          pause 30
          low led
        next i
    goto loop
    And, of course RX:
    define  OSC 20
    Define 	LCD_LINES	4			' Settings for a 4x20 LCD
    Define	LCD_DREG	PORTB		'   4bit mode
    Define	LCD_DBIT	4			'
    Define	LCD_RSREG	PORTB
    Define	LCD_RSBIT	3
    Define	LCD_EREG	PORTB'
    Define	LCD_EBIT	2
    DEFine HSER_BAUD 2400
    'LCD Lines constants
    row4        con	$d4
    row3	    con	$94
    row2	    con	$c0
    row1	    con $80
    hser var byte
    intcon=0
    lcdout $fe,1
    lcdout $fe, row1, "** RX TEST **"
    loop:
          hserin [wait($66),hser]
          hserout [#hser]
          lcdout $fe, row3," hser: ",dec1 hser
    goto loop
    Congratulations!
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 21:48
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. CM02 and RF04 wireless modules problem
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 14th December 2006, 11:32
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
