PIC to AC 220 V switch
Results 1 to 10 of 10
    Yes if you drive inductive and you don't use Snuberless Triac
    Oct 2007
    Default Try this!
    go to www.mouser.com
    Take a look at this part no. G3NE-210T-US-DC5
    There are a whole series of optically isolated solid state relays that can do the job directly from the output of a pic.
    This one takes about 20ma of drive at 5v and can safely switch 220VAC at 5 amps. It cost about $12
    Jan 2007
    Default Ssr
    12$ it is quite expensive in comparison with relay, which cost 1 - 2 $.
    Quote Originally Posted by boban View Post
    A bit overly complicated, not to mention more expensive than your option, but does provide almost perfect isolation..........
    I took a PIC, a servo, and a standard household light switch....
    Drilled a hole thru the light switch 'handle', connected it to the servo with a length of plastic, connected the servo to the PIC, wrote some software to poll a serial input, and run the servo as required.
    Again, not cheap, but does allow for a 3-5v signal to switch a high voltage at a current only limited by the switch itself. And I stored the latest switch position in eeprom in case the PIC reset itself for some odd reason...
    Small battery pack of AAA's, small wall wart style for charging the battery pack, very low current charging, blah blah blah...
    At any rate, works like a champ.
    malc-c's Avatar
    malc-c Guest
    Solid state relay works well - and can be had for around £2 a pop off flea-bay.
    I used 8 in a disco light project a year or so ago, and you can drive them direct from post PICs. The ones I used are rated at 4 Amps at 240 V, and were PCB mounted, and coped with switching 200w of spot lights with ease
  1. How can I get a PIC to switch 2.5V DC to my Opamp pin?
    By HankMcSpank in forum Schematics
    Last Post: - 9th January 2010, 22:04
  2. how to connect ac sensor to PIC ?
    By iugmoh in forum Schematics
    Last Post: - 1st June 2008, 18:35
  3. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 19:40
  4. PIC network over AC 220V
    By boban in forum Schematics
    Last Post: - 6th June 2007, 10:31
  5. Battery Backup with PIC controlling switch
    By Dwayne in forum Schematics
    Last Post: - 27th December 2003, 13:16
