picbasic +12c508a+soft_stack error
Results 1 to 37 of 37
    Tim's compiled to 15 words.
    Here's 13 ...   Note: LED's go to VDD
        list      p=16F628A
        #include "P16F628A.inc"
        errorlevel  -302        ; suppress message 302 from list file
        __CONFIG _CP_OFF & _BODEN_ON & _MCLRE_ON & _WDT_ON & _PWRTE_ON & _LVP_OFF & _INTOSC_OSC_NOCLKOUT
        clrf    PORTB         ; PORTB all 0's
        bsf	    STATUS,RP0    ; Bank 1
        bcf	    OPTION_REG, 0 ; 1:64 prescaler to WDT
        bcf     TRISB, 0      ; set RB0 to output
        bsf     STATUS, C     ; set carry flag for rotation
    Loop
        btfss   TMR2, 3       ; switch Left/Right every 8 times
        rlf	    TRISB,F       ; rotate Left across TRISB
        btfsc   TMR2, 3
        rrf     TRISB,F       ; rotate Right across TRISB
        btfsc   STATUS, C     ; No sleep if output rotated into carry
        sleep                 ; nite nite
        incf    TMR2          ; Timer2 used for it's 00 value on reset.
        goto    Loop          ; Repeat
    EDIT: Rats!
    While it works in MPSIM, it's not going to do it on the real thing.
    Time for a breadboard.
    OK, ignore the last one. That's what I get for using a simulator.
    This is 14 WORDS, 1 less than Tim's.
    At least it beats him
        list      p=16F88
        #include "P16F88.inc"
        __CONFIG  _CONFIG1, _XT_OSC & _CP_OFF & _BODEN_ON & _MCLR_ON & _WDT_ON & _PWRTE_ON & _LVP_OFF
        bcf     TRISB, 0      ; RB0 output
    Loop
        sleep                 ; nite nite
        btfss   SPBRG,0       ; SPBRG used for it's 00 reset value
        btfsc   SPBRG,0
        btfss   TRISB, 7      ; At LED7? - go the other way
        incf    SPBRG,F
        btfss   TRISB, 0      ; At LED0? - go the other way
        incf    SPBRG,F
        goto    Loop          ; Repeat
    LED's go to VDD.
    Tested, working on 16F88, should be the same (except configs) on 16F628A.
    yup.. hence why i never trust sim...
    Nice work DT.
    Here's one at 13 words.
      list      p=16F628A
      errorlevel  -302
      __CONFIG _CP_OFF & _BODEN_ON & _MCLRE_OFF & _WDT_ON & _PWRTE_ON & _LVP_OFF & _INTOSC_OSC_NOCLKOUT
       clrf  PORTB        ; clear port
       bcf   TRISB,0      ; RB0 = output
       bcf   OPTION_REG,0 ; 1:64 prescaler to WDT
    Left
       sleep             ; go to sleep for 64 * 18mS ~1 second
       rlf   TRISB,F     ; rotate bit across portb from lsb to msb
       btfsc TRISB,7
       goto  Left
    Right
       rrf   TRISB,F  ; rotate bit across Portb from msb to lsb
       btfsc TRISB,0
       goto  Right
       goto  Left     ; now rotate back to the left.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Oh Yeah! Very nice Bruce.
    Now that's going to be hard to beat.
    If you don't hear from me for a month.
    You'll know what happened.
    I just checked on my '628A on my breadboard...about a ba-zillion times...
    I set up code/hardware to do nothing but RESET, and put Port B onto a bank of LEDs, Vdd on the other side of the LED.
    EACH time, Port B came up ZERO...no LEDs lit up, until I set a TRIS bit for output.
    So, my submission...
    Coming in at 12 bytes...
      list      p=16F628A
      errorlevel  -302
    ;   clrf  PORTB        ; clear port - not required on my breadboard, might be different on others
    Left
       btfsc TRISB,7
       goto  Left
    Right
       btfsc TRISB,0
       goto  Right
    Somebody else check this out and see what happens.
    As I stated, maybe it's my breadboard, maybe it's my 628A (I've only got 1 left), maybe it's the rise time on my PSU.
    EDIT: Datasheet says that the port registers come up in an unknown state. Apparently, in this case, I now know my state...
    It might work on one series, but I wouldn't count on it as being reliable across the board.
    I have seen various PICs come up with totally random values in port latches at POR, so
    you really do need to clear portb latches first if it's to be reliable.
    -Bruce
    tech at rentron.com
  1. Loop with two motor and 2 sensors
  2. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  3. pbp245 compliation error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2006, 06:59
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 10:47
